Bike leaking motor oil? Wtf - Club700XX - Honda TRX700XX Forum
post #1 of 7 Old 02-17-2013, 12:25 AM Thread Starter
Bike leaking very little from under/ right next to the rear brake pedal under
Factory plastic?
LAKERS
mike700xx2008 is offline
post #2 of 7 Old 02-17-2013, 08:56 AM
thats what i was thinking too, check all the bolts under there for being loose and tighten if needed there is a washer on drain plug- it may be gone and not sealing right? i think oil drain is on shifter side though
post #3 of 7 Old 02-17-2013, 09:00 AM
It's been a long winter here, and my memory is not the best. I think drain plug is by foot sifter on left side. And oil filter is on the brake, or right side, did you recently do a oil change? If not I'd say do one, and make sure filter is in right and check that rubber gasket seal.
post #4 of 7 Old 02-17-2013, 09:01 AM
lol yea that's why I changed my post... early here, or late last night idk
post #5 of 7 Old 02-17-2013, 09:07 AM
And if something is broke in engine you should check for metal, in oil while doing the oil change.
post #6 of 7 Old 02-18-2013, 02:41 AM Thread Starter
Yeah got to check it asap hopefully it aint
The gasket!
LAKERS
post #7 of 7 Old 02-18-2013, 10:32 AM
easystreet's Avatar
Pull the skid plate off and look under. Stand the quad up if easier. If you haven't done any maintenance recently and its a new leak I would check for possible rock damage. Otherwise, something is loose or too tight and cracked.
'08 710XX
+3mm HotRods stroker crank
Port & Polish (myself)
HotCam 3
Velocity intake
PCV (dyno tuned)
easystreet is offline
Tags
leaking, oil, trx700
