Need Good Advice - Club700XX - Honda TRX700XX Forum
post #1 of 16 Old 04-14-2013, 04:15 PM Thread Starter
Need Good Advice
ok guys i have a chance to buy a mint 09 700xx. i have never drove one however i have heard that they struggle when it comes to wooded trails. i live in northern new york and have plenty of places to ride, but at one point or another i run across more than a few tight spots where lugging down and crawling over stuff is necessary. what should i do? i dont want a quad that stalls out in the rough stuff but i need irs for where i ride, i want a quad with some balls too, any suggestions???
mitch57 is offline
post #2 of 16 Old 04-14-2013, 07:20 PM
Change the front sprocket for a 13t. If you have the cash a fuel controller and a full exhaust would improve the acceleration if you actually need it.
NavyNut is offline
post #3 of 16 Old 04-14-2013, 07:22 PM
Buy it, put a 13t front sprocket on. And don't listen to those that tell you this quad struggles in the woods. Learn to ride it, and ask them to try and keep up! And welcome to the club!
M_Quick is online now
post #4 of 16 Old 04-14-2013, 07:48 PM
thats my advice X 2 this thing hauls the mail in the woods!
post #5 of 16 Old 04-14-2013, 07:52 PM
+2 that thing is fast in the woods with the independent suspension.
NavyNut is offline
post #6 of 16 Old 04-14-2013, 09:26 PM
mitch57,
This is a great machine for the woods and all riding conditions. Good clearance, plenty of power through the range (13T is a must). Dependable and well made. JMO
post #7 of 16 Old 04-14-2013, 10:06 PM
Quoted: 5 Post(s)
You won't be disappointed!
Change the front sprocket to 13 tooth, get the L8ton sway bar and you'll be on your way!
2008 Honda Trx700xx
2007 Yamaha Wolverine 450 4x4
2009 Raptor 90
2005 Polaris 50
Snowdog is offline
post #8 of 16 Old 04-15-2013, 07:06 AM
Where in NY do you live? I've taken mine all over, from the southern tier up to Boonville/Tughill, and haven't had any problems. I've even raced it in a tight wooded races. You'll be fine!
post #9 of 16 Old 04-15-2013, 12:12 PM
I have to agree with changing to a 13t front sprocket... gives you better low end in all gears. I'd also add a CCP steering stabilizer and a 9/16" sway bar... Total cost under $500
Plus learning to ride an IRS would help.
post #10 of 16 Old 04-15-2013, 06:26 PM Thread Starter
thanks for the imput guys, what tires are you guys running on your machines this one still has the stock crappy dunlap tires?
mitch57 is offline
