My new 700xx - Club700XX - Honda TRX700XX Forum
post #1 of 19 Old 07-17-2013, 10:18 AM Thread Starter
BleedRed's Avatar
My new 700xx
First off love Honda and im in love with this quad best quad ever built IMO..
just wanted to let you guys know what done to it cause and let me know what u think if i should change anything or what have you.
1. dg full exhuast not sure of model, but sounds great.
2.dyno jet progrmmer
3.uni air filter
4. Percision sterring stablaizer
5.dg front bumper.
6.not sure what size sprocket but he said stock it did 89 mph and it was unless in the trails so he put either a smaller one or bigger not sure whatever one make less top end.
its by far the fastest quad i have ever rode its almost scary fast.
Any suggestions or comments?
BleedRed is offline
post #2 of 19 Old 07-17-2013, 10:22 AM Thread Starter
BleedRed's Avatar
exhuast is a DG bullet
BleedRed is offline
post #3 of 19 Old 07-17-2013, 10:51 AM
Nice looking 700xx... welcome to our forum.
You might want to upgrade:
1. Tires (only after you wear out stockers)
2. Air filter... UNI (allows motor to breath better)
3. Air box lid... EHS (same reason as above)
4. Shocks... DS450 front, rear can be re-valved and re-sprung
5. Stiffer sway bar... L8ton (allows quad to handle and turn better)
If there is anything else you need to know about the 700xx, just ask.
post #4 of 19 Old 07-17-2013, 11:39 AM
Snoshoe's Avatar
will the DS450s work with a 250lb rider? or do i need ds650s?
2008 TRX700xx
13Tfront
Kenda Bear Claws 23x8x11
Custom 2" receiver
rear seat/ strorage box
Ground Hog Disk harrow kit
PEI fog lights
Snoshoe is offline
post #5 of 19 Old 07-17-2013, 12:22 PM
LOL. Don't think everyone on here is scrawny. I am 225 and they are fine. I don't jump the XX like my other toys, but I do hit an occasional table top and what not. They will be fine, and far better than the stockers.
post #6 of 19 Old 07-17-2013, 02:45 PM
Not many if any around here claiming 89 mph! Best I've see is 83 d/hill, but I wasn't on the rev limiter, and I'm a XXL. If your quad will idle w/out stalling it probably has a 13t front sprocket. Smaller front or larger rear sprocket gives more torque / low-end. 1st thing I would do if I was you was get some nerf's, then some skid's. There's a seller on eBay, a Honda dealer that has all the Honda stuff on close out for our quad. I'd guess roughly 65% off original pricing. If you need a link just let me know. As far as other mod's the list goes on and on, depends on how deep the pockets are.
post #7 of 19 Old 07-17-2013, 02:53 PM Thread Starter
BleedRed's Avatar
he replaced the front sporcket. and he said 87 mph sorry not 89 he had a gps speedo he was using? whatever the case is it has retard speed. my pockets are pretty shallow so wont be doing to much more to it. nerfs wheels and tires and maybe some supension mods but thats it most likely. i just wanted to know if the set up he had on it was good or could i improve it.
BleedRed is offline
post #8 of 19 Old 07-17-2013, 03:23 PM
Bleed,
Yes the set up will be fine for trail riding. The motor has more potential if you were going to dig into it, but with an exhaust, intake, and programmer, you have the big three. There are a lot of threads on here for suspension, tires and wheels. I'd look into that. As far as stabilizer, that is one of the best on the market. If you were to do engine mods, you'd have to change out your programmer for a PC3 or 5. Other than that, you should be good to go. The biggest thing I see you needing is tires, but as mentioned, let those ones wear out. Definitely go with a 6 ply tire for your next set, as they will last longer and have less puncture resistance.
post #9 of 19 Old 07-17-2013, 03:35 PM Thread Starter
BleedRed's Avatar
what are the exact tires i need, i dont want the rear to be lower like ive seen tho looks weird to me. but i like the smaller side wall and it should slide a lil better ecspecaly when i get the sway bar.
BleedRed is offline
post #10 of 19 Old 07-17-2013, 04:42 PM
Are you asking about tire size or manufacture? oem size is 21x7x10 fronts and 22x9x11 rears. The taller fronts are sweet for GNCC racing style riding. More ground clearance in front is what there after, I believe. I like 22's front and rear, then I adjust my ride hight so front is 1/2" taller. Also 23" fronts will rub some nerf bar's.
