New to the 700xx - Club700XX - Honda TRX700XX Forum
post #1 of 16 Old 08-06-2013, 01:16 PM Thread Starter
New to the 700xx
Hey everyone, I decided to join this forum because I am probably going to be buying a 700xx any day now. It's a 2008 with "supposedly" 5 hours on it. Judging by the picks it does look pretty clean but I'm sure it has more ride time then that.
I'm just wondering if there is anything that I should watch out for in the 08. I know it's the first yr but are these things as reliable as the rest of my Honda fleet? This will be my first Honda sport quad besides a 250 ex but I have a rincon, rubicon a cr125 and a crf450r. All of them have been pretty good to me which is why I wanted to go with the 700xx.
I don't really care about the performance or handling as I trust that it will be flawless and plenty powerful for me but I do worry about the reliability of a first yr model. Is it expensive and a PITA to care for or can I get away with oil changes and basic maintenance and ride it for 10 yrs. I don't beat the crap out of any machine so that won't really come into play. Just mildly aggressive riding from time to time but mostly steady cruising.
Sorry about the length of this post and thanks in advance
Hondar24 is offline
post #2 of 16 Old 08-06-2013, 02:29 PM
They only made these for two years, and they are as reliable as they come. Hardly anyone has had any real issues. The maintenance on it is the same as your 4x4's, same oil filter too. No where near as high maintenance as the crf450. I think you will be very impressed. Just be sure to change the oil, check the valves, and have fun. There is a thread on here for what to check when you first get it, as some have had problems, like the mud scrapers and the petcock for the gas being backwards. All minor stuff. Very few have blown them up, which I did mine do to submerging a little too far in water. Other than that, very few problems. Hardest thing is wheels/tires, and the difference in feel between a SRA and a IRS. If you pull the trigger, with out a doubt you will love it considering I have most of the same "other Hondas" as you.
Chuck
post #3 of 16 Old 08-06-2013, 03:23 PM Thread Starter
That's exactly what I was hoping to hear. I couldn't find much about problems with the bikes but just wanted to make sure. I'm glade to hear that the maintenance isnt really an issue either as that is something I learned to love about all Hondas.
I'm probably going to look at one tomorrow and if all goes right then I should have it and be driving it this weekend. Thanks for the response man
Hondar24 is offline
post #4 of 16 Old 08-06-2013, 03:25 PM Thread Starter
Good to see your in upstate also, I figured it would be a good fit for this type of terrain in NY
Hondar24 is offline
post #5 of 16 Old 08-06-2013, 03:57 PM
If/when you go look at the bike, grab the right rear axle and shake it. Check for play, if low hours like they say it's probably fine. Add removing right rear axle and lubing the inboard joints to your maintenance list. Usually you can tell low hours by the oem tires, atleast most would not replace the tires with the junk/over priced dunlops.
post #6 of 16 Old 08-06-2013, 04:39 PM Thread Starter
Some like great advice, thanks man, buy why is it only the right side? Also have you or anyone else had an trouble with the stock air filters sucking in a lot of dirt? Seems to be one of the only things I'm hearing but I'm not really sure how true that is
Hondar24 is offline
post #7 of 16 Old 08-06-2013, 05:07 PM
The stock filter is just like all the other Honda quads. A lot of guys get the UNIs. Foam filter is the best IMO. Where in upstate are you? I actually am in the southern tier, so not really upstate.
post #8 of 16 Old 08-06-2013, 07:02 PM Thread Starter
Im in Norwich , it's about 40 miles from binghamton in Central New York
Hondar24 is offline
post #9 of 16 Old 08-06-2013, 08:03 PM
As far as the right side axle, there has been a few problem's occurring with whats called the inboard joints. The right joint goes inside the left, like the right is the male and the left is the female. This is not a cv joint issue, but a good idea to check those on both sides as well.
As for the stock filter, I don't see how it would pass dirt. It is far more restrictive than the uni filter, which is what most people use. And they work well if cleaned and oiled as needed.
post #10 of 16 Old 08-07-2013, 06:46 AM
No kidding, I am in Greene LOL. Small world. We will have to get together sometime. We tend to ride sometimes from Smithville over to the OUTPOST, on 220 just outside of Oxford, plus a few other bars up towards Balsam. If you want help taking a look at it, I've had mine since it first came out. I wouldn't mind helping ya out. I have to head to Norwich one night this week anyway to hit Country Max. My name is Chuck.
