Little Sahara, ok - Club700XX - Honda TRX700XX Forum
post #1 of 3 Old 09-07-2012, 08:39 AM Thread Starter
jjiles63's Avatar
Little Sahara, ok
heading to OK on the 18 to 20 with some friends from work. will be first time don't have paddles hope the bike will do fine. anyone got any info that might help.
11/16 sway bar
FMF controller
13 t front sprocket
jjiles63 is offline
post #2 of 3 Old 09-11-2012, 05:39 AM
If I were you, I would bite the bullet and get the paddles. That sand is pretty loose. We had a few different paddle brands, and the only ones that didn't have any problem with leaks were the ITP Sand Stars. Something about the bead itself is a bit beefier, and matches the ITP aftermarket rims better. But I'm no tire guy.
We had an absolute blast, and I never even tried it without the paddles on the 700XX. But they still felt necessary, if that makes sense. My big Can Am did fine without paddles, but I think that's because the 26" tires roll easier in the sand.
Tom
08 Outlander 800
08 Yamaha Big Bear 400 4x4
OHV Wildcat is offline
post #3 of 3 Old 09-23-2012, 01:35 AM
You can go without the paddles. I used to go to little sahara all the time with my 250r's without paddle tires and had no problem. I did howerver end up buying a set of ITP V groove paddle tires to make it easier. The 700xx has plenty of torque just go check it out and then decide if you need paddles tires. Damn I wish i was closer to little sahara I would go with you. Great park, I have heard that Oklahoma has redone all the parks dont know about this one. The showers were a little ratty about 10 years ago.
hvtexskeeter is offline
