weight loss - Club700XX - Honda TRX700XX Forum
post #1 of 68 Old 06-11-2009, 06:37 PM Thread Starter
weight loss
Any Ideas , I want it down to 425 lbs. I do cross country which means no lights etc.etc.
post #2 of 68 Old 06-11-2009, 08:32 PM
Take a box of ExLax and that should about drop 30 pounds overnight Geez 80lbs is a lot to take out. But I guess lighter wheels and tires, and carbon fiber anywhere you can manage to put it. Not sure where else you can take it from.
2007 Yamaha R1 Charcoal/Black
THREESVTS is offline
post #3 of 68 Old 06-11-2009, 08:41 PM
Titanium parts, lighter shocks, the stock ones weigh a ton. The engine actually weighs less than a 450r's does.
Oh and the stock exhaust is heavy as well.
post #4 of 68 Old 06-11-2009, 08:44 PM
OzLinc's Avatar
425lbs wet...........ummmmm...........thats alot of weight saving.
Gutting the electrics will save you a bit but not that much. Maybe if you ran 4 x Fox Floats......????
IMO most of the extra weight on the 700XX is in the engine. It's a heavy engine in the first place but then you add the sub-transmission and you end up with one heavy mother.
In some circumstances I think the weight helps. The extra weight is central and keeps the quad planted when some others tend to get kicked about because they are so light.
Linc
OzLinc is offline
post #5 of 68 Old 06-11-2009, 08:51 PM
OzLinc's Avatar
I haven't weighed it so I can't say for sure but I cant see a 450R engine weighing more than the 700XX's. The 700XX has bigger everything plus reverse and the sub-trans where the 450R is based off a MX engine
.............it's got to be lighter.
I do agree that you could save a ton from the exhaust.
Linc
OzLinc is offline
post #6 of 68 Old 06-11-2009, 09:52 PM
I actually read that, I'll site my source as soon as I find it.
I can't find it...grrrrr
post #7 of 68 Old 06-11-2009, 09:56 PM
Originally Posted by OzLinc View Post
425lbs
Linc
I would say it's mostly in the rear suspension. You have 2 of everything. 2 shocks, 2 springs, 2 upper and 2 lower a arms. It's heavy duty stuff built to withstand most of what the average rider will throw at it.
post #8 of 68 Old 06-11-2009, 11:48 PM
OzLinc's Avatar
I agree that the IRS setup is heavier but to get a more accurate (guess) idea you only need to check the weight difference between the Poolaris Outlaw 525s and the Outlaw 525IRS..........not as much as you may think.
369lbs vs 398lbs........
If the Outlaw IRS weighs 400 dry and the 700XX weighs 485 dry (thats a guess) then where has the extra weight come from?
That said; the combination of IRS and the 700 engine surely has made the XX in to a porker.
OzLinc is offline
post #9 of 68 Old 06-16-2009, 10:04 PM
get an LTZ400
SNEAKY is offline
post #10 of 68 Old 06-17-2009, 06:17 AM
Originally Posted by SNEAKY View Post
get an LTZ400
Yeah and not only would be able to work on it all the time to fix things that fell off, broke, or failed, you'll also have the pleasure of having a little more than half the power of the 700xx
