2013 - Season 5 racing the XX
Has it really been that long , playing with the 700xx. Time fly's when you find the right quad.
Anyway's the 700xx is taking some building and seem to be running into a few problems that nobody else seems to have.
Hence bought a very lean 2003 400ex to help out by scoring some points whilst I sort out the 700xx.
Managed to fit Ed's stem, Easton bars and S'n'V clamps off the 700xx , oh and the the front brakes,hubs and knuckles. Other than that a completely stock 400ex. Scored some points but nothing close to what I would have got on the 700xx.
Sponsored Links | |||
What kind of problems you having Baxter? Maybe someone here can help.
The main problem is the gearbox. I have replaced 3rd gear, 4th gear , shift drum and shift shaft 3 times in 2012. Replacing the whole gearbox to cure this ,hopefully. Then we have the 9 litres of fuel in 31 minutes. They say the 700xx does not have a "Grey" wire , I say they are wrong. I have tried everything , Big 3 and added HC3 and it still runs stronger running the modded airbox , 250r Uni filter and EHS programmer and a stock exhaust.
I think I know why the gearbox goes and have bought Kyle's 11/16 swaybar to cure this but even stock 90 mins on a tank of gas is ?
I'm going to rebuild the 700xx over the next 12 months and cure some problems because this is the ultimate quad. I want to do some races in France because ,I own a 700xx. Even looking into buying a new short motor from Honda because , I love it so much. I have far to many parts,friends,ideas and a XR650r head to give up now.
dang i thought you had a 450R too. wouldnt you rather race a 450 R compared to the outdated 400ex and the 450R is rather outdated compared to other brands. and as far as gearbox problems on the 700XX you are the only one so far ive heard have that problem?
Lee, when I run mine hard, I can get about an hour and 45 minutes before I need to put it on reserve. You could always get an oversized tank.
1 1/2 hour on a stock engine. You have a built motor Chuck. If I put the big 3 one it has a stint of 30 minutes before reserve. Did it twice now. The 727cc motor will probably have a FCR carb and 400ex ignition. The 710cc motor stock ignition and +3 TB.
Only 30 minutes? Something is drastically wrong then. Especially if you have it stock. Is there a leak somewhere? Get a really big Camelback and fill it with gas with a gravity line going into the vent of the tank
May be a tad heavy on your back though. HAHA.
i can ride basically as long as i want with the stk tank being full and a big 3 motor is what i have and believe me after burning up the stock tank being full i am wore out! you should get better gas mileage BAX!
iam talking about my 700XX!
30 mins with big 3 fitted. Its the only time it feels faster than stock . Lol. Nearly ran out fuel at first beach race .Used 2 days of gas in 1 practice session and 2 races. Qualified for Pro class though. We were thinking either heat of the engine boiling the tank and or faulty efi control unit etc.
Sponsored Links | |
Thread Tools | |
Display Modes | |
Posting Rules | |
