The Best Way to Install a Winch - Club700XX - Honda TRX700XX Forum
post #1 of 1 Old 11-22-2014, 08:27 PM Thread Starter
xxcharger's Avatar
I have another post showing my winch front bumper but that was too low and kept hitting the ground so I took that off and decided to put the winch on the rear. So this is very basic and easy but requires a welder. It's also easily removable by removing 3 bolts which I may replace with Hand knobs and put plug/unplug wiring and use like a portable winch. So pretty much I took the plate that comes with the winch and added on to the bottom. Then it bolts onto a simple plate u-bolted on the back of the quad. I don't think I'm that great at writing so here's some pictures.
2008 700xx red/black
UNI air filter, EHS EFI controller, Moose 13T sprocket, JnJ Skid plates, DDM HID headlight, L8ton 9/16 sway bar, IMS Fuel tank, FMF Factory 4.1 with spark/quiet insert, FMF Powerbomb header with wrap, Superwinch, Garmin eTrex 30 GPS w/ ram mount, Pro Taper SE Handlebar, ITP T-9 GP front wheels, Alba nerf bars, DS 450 XMX front shocks
xxcharger is offline
