some suspension setting info inside - Page 3 - Club700XX - Honda TRX700XX Forum
post #21 of 24 Old 01-14-2011, 10:14 AM
ziggy's Avatar
Hey guys just though I would mention that with a group buy we will more than likely be cheaper than that imo. check it out at:
https://www.club700xx.com/vb/showthre...?t=5638&page=4
2008 700xx -Blk-n-Gry (the faster one
13 Tooth Renthal Sprocket, L8ton Racing sway bar (both),MotoActiv Chivarly Bumber, EHS BIG 3, Kenda Kutters!
ziggy is offline
post #22 of 24 Old 01-14-2011, 12:30 PM
08700xx's Avatar
Thanks for the link, I would be in for some elka 3's if I can get some time to recover from the 3300 I just put into the motor.
08700xx is offline
post #23 of 24 Old 01-14-2011, 04:40 PM
Stage 2 for fronts is only $709 on ishock.com and that would make a world of difference on it's own
post #24 of 24 Old 01-15-2011, 12:27 PM
08700xx's Avatar
That’s not bad at all. Once I'm done with the motor shocks will be next for sure, hopefully we will have a group buy going by then.
08700xx is offline
