Removing Reverse rev limiter - Page 2 - Club700XX - Honda TRX700XX Forum
post #11 of 117 Old 01-26-2010, 06:40 AM
atleastitsnotaford's Avatar
Could also try a bicycle shop. That's what I did for the throttle on a custom goped I built. Throttle cable was nearly 8 feet long.
atleastitsnotaford is offline
post #12 of 117 Old 01-26-2010, 12:52 PM
Simplyorange's Avatar
ok, so do you cut all the way through the wires and only attach the 2 on the wiring harness, or do you just strip them and bridge them together?
2007 GSXR 1000 (Orange/Black)
Simplyorange is offline
post #13 of 117 Old 01-26-2010, 05:32 PM Thread Starter
duravette's Avatar
Cut both wires and just connect the two wires from the wiring harness together.
2008 Honda 700xx
-CP Piston 12:1 & Web Stage 2 Cam
-13t Sprocket
-Trail Tech Vapor
-Trail Tech HI-Rise Bar Clamp
-PRM Front Bumper
-PCV w/autotune
-Two Brothers slip on
-Reverse Rev Limiter Removed
-Reverse Lever Located to Handle Bars
-Warn 1500 lb Winch
duravette is offline
post #14 of 117 Old 01-26-2010, 05:43 PM Thread Starter
duravette's Avatar
Originally Posted by aschuck View Post
Thanks for all the good info.
Can I see some pictures of your winch?
http://s476.photobucket.com/albums/r...ette/TRX700XX/
2008 Honda 700xx
-13t Sprocket
-Trail Tech Vapor
-PRM Front Bumper
-PCV w/autotune
-Warn 1500 lb Winch
Last edited by scuzz; 01-26-2010 at 05:58 PM. Reason: Thought I would help you out!
post #15 of 117 Old 01-26-2010, 10:28 PM
VOO-DOO's Avatar
Originally Posted by duravette View Post
You buy the winch mounting plate, or did you make your own?
2008 Black/Charcoal 700xx
Mods:
FMF Stainless Powerbomb header
FMF Titanium Muffler
FMF Programmer
Uni- air filter
10" ITP aluminum wheels with 22" Sand Stars
JT 13T sprocket, with Billet Specialties case saver
and I have a bottle of NOS if needed!
2009 Honda Foreman ES 4x4
Full chasis skid plate, Warn 2500 winch (field tested and approved!), 14" SS wheels wrapped in 26" Baja tires.
I don't have to be the fastest to have fun!
VOO-DOO is offline
post #16 of 117 Old 01-27-2010, 01:31 AM
aschuck's Avatar
Duravette,
That is a great install of your winch.
Can you provide us with part numbers or links so we can build one. (winch,roller things,bumper,anything else that we need.)
Also does it mount where a steering stabilizer mounts.
A picture where it mounts would be great.
Thanks
Alex
aschuck is offline
post #17 of 117 Old 01-27-2010, 11:18 PM Thread Starter
duravette's Avatar
Duravette,
Thanks
Alex
http://i476.photobucket.com/albums/r...X/IMG_0123.jpg
I had to make the winch mount. The hardest part was make a mount that would relocate the upper shock mounts out one inch. You can see this in the photo. Were you see the D-ring thats ware the shock was mounted. The D-ring is great for a anchor point. The nice thing was I didn't have to cut or weld anything to the frame. Far as moving the shocks out one inch I haven't noticed any handling difference.
Parts list:
WARN XT15 12V DC ATV Winch ó 1500-Lb
Part Number: 78500 $399.00
PRM-ATV
Baja Bumper SKU: XX701 $89.95
Some Custom Mounting Plates
Part Number: You!!! $???.??
One Tennis Ball
Part Number: ? $0.??
2008 Honda 700xx
-13t Sprocket
-Trail Tech Vapor
-PRM Front Bumper
-PCV w/autotune
-Warn 1500 lb Winch
post #18 of 117 Old 01-28-2010, 09:14 AM
well, you just made my front bumper choice very easy.got any pics of the winch mounting location and the shock relocation?
post #19 of 117 Old 01-30-2010, 02:24 AM
blkcruzer's Avatar
Curious as to how many people have actually done this yet? I did it tonight, along with tapping into wire 11 for the tach lead to my TT Vapor. It was a little tricky to even find the pcm, and once I did locate it, those wires are SHORT and don't give ya a great deal of room to work!! I got it all done, but haven't started it back up to try it out, just gone done checking the valve clearances after about 20 hours of riding since new, they were spot on!! Look forward to getting the EHS big 3 on and getting her back together!!!!
blkcruzer is offline
post #20 of 117 Old 01-30-2010, 11:06 AM
I wanna see some people post some GPS verified reverse numbers.
(don't, that was sarcasm)
