Removing Reverse rev limiter - Page 3 - Club700XX - Honda TRX700XX Forum
post #21 of 117 Old 01-31-2010, 01:03 AM
vfm2010's Avatar
I wanna see some people post some GPS verified reverse numbers.
(don't, that was sarcasm)
Will a GPS display negative numbers?
88 LT500R QUADZILLA
06 DVX400 (Son's)
06 TRX250EX (Wife's)
vfm2010 is offline
post #22 of 117 Old 02-01-2010, 09:52 AM
Simplyorange's Avatar
Originally Posted by duravette View Post
http://i476.photobucket.com/albums/r...X/IMG_0123.jpg
I had to make the winch mount. The hardest part was make a mount that would relocate the upper shock mounts out one inch. You can see this in the photo. Were you see the D-ring thats ware the shock was mounted. The D-ring is great for a anchor point. The nice thing was I didn't have to cut or weld anything to the frame. Far as moving the shocks out one inch I haven't noticed any handling difference.
Parts list:
WARN XT15 12V DC ATV Winch ó 1500-Lb
Part Number: 78500 $399.00
PRM-ATV
Baja Bumper SKU: XX701 $89.95
Some Custom Mounting Plates
Part Number: You!!! $???.??
One Tennis Ball
Part Number: ? $0.??
whats the tennis ball for? , do you have pics of your mounting polate and bolt down points, and did you just have to redrill for the shocks or is that a fabbed bracket? and for the front rollers, did it come with the winch?
2007 GSXR 1000 (Orange/Black)
Simplyorange is offline
post #23 of 117 Old 02-02-2010, 10:42 PM Thread Starter
duravette's Avatar
The tennis ball keeps the roller from vibrating and from making noise. Here is a link for some photos. http://s476.photobucket.com/albums/rr125/duravette/TRX700XX/ The mounting plate has tabs that are bolted to the upper arm mounting tab on the frame, and after relocating the regulator to the under side of where it was mounted. the mounting plate bolts to the place where the regulator was. In the photo you can see the red arrows and yes I did have to make a bracket for the shocks to move them out about 1 inch.
And for the rollers yes I did have to buy them, but it depends on the model of the winch that you buy if it comes with them or not.
Sorry I didn't have any photos of just the mounting plates.
I hope this helps you.
2008 Honda 700xx
-CP Piston 12:1 & Web Stage 2 Cam
-13t Sprocket
-Trail Tech Vapor
-Trail Tech HI-Rise Bar Clamp
-PRM Front Bumper
-PCV w/autotune
-Two Brothers slip on
-Reverse Rev Limiter Removed
-Reverse Lever Located to Handle Bars
-Warn 1500 lb Winch
duravette is offline
post #24 of 117 Old 02-03-2010, 07:03 PM
i hope the mounting plate is secured by more than the 8mm bolts from the regulator.
post some pics if you get a chance. I'd like to see the plate.
BlackSheep is offline
post #25 of 117 Old 02-03-2010, 08:44 PM
if i understand correctly, the regulator was just relocated to make a flat spot, i believe he has tabs that go down and he ran the bolts for the a arms throught the tabs.
post #26 of 117 Old 02-03-2010, 09:12 PM
Guys,
Let's keep this on topic if you don't mind and make a new thread about this please.
Thanks!
Gary
post #27 of 117 Old 02-03-2010, 09:16 PM Thread Starter
duravette's Avatar
I don't have any photos of the mounting plate by itself. But if you look closer in the photo's you can see the mounting plate has tabs on it which are bolted through the upper a arm bolt. Trust me I wouldn't have gone to all this work to mount it with only two 8mm bolts.
2008 Honda 700xx
-13t Sprocket
-Trail Tech Vapor
-PRM Front Bumper
-PCV w/autotune
-Warn 1500 lb Winch
post #28 of 117 Old 02-04-2010, 10:04 PM
that's all badass... i dont care if its on topic or not... i'm doing the reverse switch (which looks a lot like the Dr D for the raptor) and possibly the winch. That's totally cool.
post #29 of 117 Old 02-04-2010, 11:57 PM Thread Starter
duravette's Avatar
Thanks. Its nice to hear some feed back
2008 Honda 700xx
-13t Sprocket
-Trail Tech Vapor
-PRM Front Bumper
-PCV w/autotune
-Warn 1500 lb Winch
post #30 of 117 Old 02-09-2010, 11:11 PM
kennyg700xx's Avatar
little help?
sorry for being so stoopid,but, I love my xx, before i go cutting wires, I want to know i got it right. OK, so, under the left side fender I can see a box mounted to plastic, almost touching the radiator, it has 4 or five wires sticking down( that I can see) It has the green and the green/black wires. are these the correct wires? if not, please help. you can bust my balls or laugh at me, if you want, just please help me out. I'm tired of the reverse limiter in the snow.
2008 honda700xx
2007 honda250ex(wifes)
2009 FORD F150 supercab
kennyg700xx is offline
