Removing Reverse rev limiter - Club700XX - Honda TRX700XX Forum
post #1 of 117 Old 01-23-2010, 06:54 PM Thread Starter
duravette's Avatar
Here is what I did. First get your service manual. Look on page 22-3 wiring diagrams. Looking at the ECM lead #8 and #25. You will have to carefully cut back the black tape to get enough length. Cut these two wires back a little over an inch back from the connector. Splice and solder these two wires together. I used some heat shrink to protect them. Wrap them all with some good electrical tape. By doing it this way your reverse light still works
2008 Honda 700xx
-CP Piston 12:1 & Web Stage 2 Cam
-13t Sprocket
-Trail Tech Vapor
-Trail Tech HI-Rise Bar Clamp
-PRM Front Bumper
-PCV w/autotune
-Two Brothers slip on
-Reverse Rev Limiter Removed
-Reverse Lever Located to Handle Bars
-Warn 1500 lb Winch
duravette is offline
post #2 of 117 Old 01-23-2010, 09:11 PM
Thanks Duravette, Detailed post like this are great!
post #3 of 117 Old 01-24-2010, 01:36 PM
b.courtney_700xx's Avatar
i am kinda interested in ur reverse lever on the handlebars got any pics of that?
b.courtney_700xx is offline
post #4 of 117 Old 01-24-2010, 11:46 PM
vfm2010's Avatar
Great Post! Thank You DuraVette!
88 LT500R QUADZILLA
06 DVX400 (Son's)
06 TRX250EX (Wife's)
vfm2010 is offline
post #5 of 117 Old 01-25-2010, 02:37 PM Thread Starter
duravette's Avatar
I used a Hot start lever mounted on the front brake clamp. I used a old electrical cord to get the right lengh for the new cable that I had to have made up. Works great.
2008 Honda 700xx
-13t Sprocket
-Trail Tech Vapor
-PRM Front Bumper
-PCV w/autotune
-Warn 1500 lb Winch
post #6 of 117 Old 01-25-2010, 04:36 PM
sweet thx man
post #7 of 117 Old 01-25-2010, 08:51 PM
i was gonna use a crf hotstart lever/perch on the cluch side, but have not been able to find the proper length cable. where did you have it made?
BlackSheep is offline
post #8 of 117 Old 01-25-2010, 09:42 PM
aschuck's Avatar
Thanks for all the good info.
Can I see some pictures of your winch?
aschuck is offline
post #9 of 117 Old 01-25-2010, 09:45 PM
That is so awesome.
God job.
post #10 of 117 Old 01-25-2010, 11:02 PM Thread Starter
duravette's Avatar
I had mine made at a local shop, He used a clutch cable with new ends on it. The problem is the cable is to thick and stiff. It needs to be made with a choke or a throttle cable. I was thinking of having it redone using Motion Pro out of California. lhttp://www.motionpro.com/search/motorcycle/black_vinyl_oe_replacement_cables/
2008 Honda 700xx
-13t Sprocket
-Trail Tech Vapor
-PRM Front Bumper
-PCV w/autotune
-Warn 1500 lb Winch
