done to get more oil to the overhead cam
parts needed ; 12mm 1.0 thread x 3AN flare banjo fitting
20'' oil line w/90 degree end
1/8NPT 3AN 90 degree fitting
drain coolant and remove water pump , remove 12mm 1.0 plug from housing , remove valve cover drill and tap hole to 1/8 NPT . and replace back on to head
install banjo fitting bolt in to housing ,attach oil line , tighten fittings, replace water pump and coolant
the banjo fitting i used had to be modified ,drilled out to except a 12mm bolt . if you get the same one i did expect to perches a different bolt
