2008/09 700xx Oil Change - Page 3 - Club700XX - Honda TRX700XX Forum
post #21 of 203 Old 04-16-2009, 02:25 PM Thread Starter
Originally Posted by double_0_xx View Post
Just being picky.. I did not see a pic of the spring..
Thanks for the feedback, I'll add that tonight when I'm taking my pipe off and changing the oil.
It's my son's birthday, so it may not happen.
post #22 of 203 Old 05-09-2009, 04:06 PM
WhiskeyDelta's Avatar
I'm getting ready for my first oil change. Great write-up Scuzz.
One question, the Honda Repair manual mentions changing the wire-mesh filter in the oil hose connector. Is this something that needs to be done on a regular basis with the oil changes? It seems a little more complicated because it says to use a special kind of solvent to clean (flash solvent?) and then use canned air to blow dry.
2008 Honda TRX700XX
DG V-Pro Front Grab Bar/HID Headlights/Flexx Handlebars/Fasst Vibration Inserts/Odi Rogue Grips/MSR Pro-Raptor Shorty Shifter/Trail Tech Vapor Computer/Trail Tech Vapor 1 1/8" Dashboard/
Velocity Racing Intake/EHS Racing Power lid/DG X2 Slip-on/
Power Commander III EFI Controller/
Skat-Trak Mohawk/Extreme on Douglas Wheels
Full set of custom 1.5" 4/110 to 4/144 Wheel Spacers/Adapters
Elka Shocks (Full Set)
DG Factory Nerfs w/Rear Nets
WhiskeyDelta is offline
post #23 of 203 Old 05-09-2009, 09:27 PM Thread Starter
THANKS!
The Honda Manual only mentions "If cleaning of each oil strainer is required (in oil tank; page 4-14. in crankcase: page 5-4) perform it before filling."
I haven't heard of anyone changing these even on the 400EX's unless the engine was letting serious amounts of metal shavings in the oil...then you probably have bigger issues than taking the screen out and cleaning it.
post #24 of 203 Old 05-10-2009, 11:38 PM
TRX_Sixpac_700xx's Avatar
Funnel with a tube!!! If you have not changed your oil yet, make sure you have one. My first attempt was with a cheap filter with about a 1-1/2" nipple on the end, and I was spilling oil because the funnel had to fit in at an angle and could still barely reach. Before my next oil change I will definitely be using a different funnel.
TRX700XX
-UNI Air Filter
-2Bros Exhaust
-2 Bros Juice Box
-13T Sprocket
-Pro Armor Fat Pegs (Black)
TRX_Sixpac_700xx is offline
post #25 of 203 Old 05-11-2009, 11:22 PM Thread Starter
post #26 of 203 Old 05-12-2009, 01:36 AM
xx-rated's Avatar
Added torque warning for filter cover.
True that. Use a smaller 1/4-inch drive if you are using a torque wrench. Believe me.
xx-rated is offline
post #27 of 203 Old 05-12-2009, 09:15 AM Thread Starter
post #28 of 203 Old 05-13-2009, 02:53 PM
xx-rated's Avatar
That was just plain stupidity on my part. Still can't believe I did it. I did feel a little better after the mechanics at the shop said that they also had sheared off case bolts with a torque wrench. The good news is they assured me it would be ready by Friday so I can still go on my ride.
Impressive sig by the way, I didn't even realize what it was until I looked at it a couple of times.
xx-rated is offline
post #29 of 203 Old 05-13-2009, 03:03 PM Thread Starter
Yeah, I've done it before on intake bolts when I was working on my SBC in my teens. It's easy to do with a torque wrench. It's a horrible feeling though when that bolt lets go and the force gets less and less.
I stole the sig off another site and customized it - I'm not that big of a nerd to be able to make that on my own.
post #30 of 203 Old 05-15-2009, 02:16 PM
BiFfMaN's Avatar
Its called ASCII art...
here are some more
http://chris.com/ascii/
BiFfMaN is offline
