EHS Big 3 Installation Instructions - Club700XX - Honda TRX700XX Forum
post #1 of 3 Old 09-10-2010, 09:34 PM Thread Starter
Question EHS Big 3 Installation Instructions
I just got a used kit with no instructions! Where do I hook up the fuel controller and how do I operate it? Do you need to remove the rear fenders? Any other tips?
mooman333 is offline
post #2 of 3 Old 09-10-2010, 10:10 PM
240
If it's the EHS controller you can get the installation instructions from this link:
http://www.ehsracing.com/install_ins..._700xx_efi.pdf
Here are the tuning instructions in case you need to tune the controller:
Page 1: http://www.ehsracing.com/install_ins...efi_tuning.pdf
Page 2: http://www.ehsracing.com/install_ins...i_tuning_1.pdf
You don't have to remove the rear fenders to install the exhaust but it will make things easier to get at.
240 is offline
post #3 of 3 Old 09-11-2010, 11:06 PM
TRX700XXX's Avatar
Just take off the heel guard plastic and side skirt things. Thats all I did and it worked. Its harder to take the stock exhaust off than putting a new one on.
TRX700XXX is offline
