Making your stock tensioner adjustable. - Club700XX - Honda TRX700XX Forum
post #1 of 10 Old 01-07-2011, 08:48 AM Thread Starter
Simplyorange's Avatar
i recently had a clutch basket failure and a timing tensioner failure, here was my solution to the timing tensioner problem, instead of paying $65 for a stock one to go out again or waiting for an adjustable one to come out, i spent about $3.50 at the hardware store and made my own, and it works perfectly.
first remove the tensioner from the bike, then disasseble it completely, throw away the washer, sleeve,screw and spiral band that acts as a spring becuse you will not need them.
where the screw was threaded into the plunger, drill it out smooth with an 11/32 or 3/8 drill bit to accept an 8mm threaded bolt.
drill the hole in the back of the housing where the 6mm bolt used to be with a 1/4" drill bit and tap it with an M8X1.25 tap.
clean everything really good and reassemble the plunger into the housing using only the retainer plate and C clip
next, put the backup nut onto the M8 bolt then the nylon washer, and screw the bolt into the back of the tensioner until it touches the inside of the plunger.
assemble it on the bike and adjust as you would any other manual tensioner using the backup nut and nylon washer to seal the oil in and lock the adjustment, see pic below.
i have a cad drawing of it but the forums limits will not let me upload it.
2007 GSXR 1000 (Orange/Black)
Simplyorange is offline
post #2 of 10 Old 01-07-2011, 09:59 AM
USMC0861's Avatar
Nice job
USMC0861 is offline
post #3 of 10 Old 01-07-2011, 10:54 AM
great job
hondalver700xx is offline
post #4 of 10 Old 01-07-2011, 10:55 AM
how much was the clutch basket bearing?
post #5 of 10 Old 01-07-2011, 11:58 AM Thread Starter
i dont remember, $16.00 maybe...
post #6 of 10 Old 03-04-2011, 02:08 PM
How tight would you tension the cam chain manualy ?
post #7 of 10 Old 03-05-2011, 09:00 PM
USMC0861's Avatar
tighten it just until you feel the plunger make contact with the guide.....start the bike.....then slowly tighten it until the rattle from the chain slap disappears....its pretty obvious when you do it... as soon as this happens, leave it and snug up the set nut. Simple as that. Another good place to look is thumpertalk.com....go to the make model specific forum, then to DRZ400...look in the FAQ forum or do a search...more info than you ever need and a great bunch of guys as well
USMC0861 is offline
post #8 of 10 Old 03-05-2011, 09:06 PM
USMC0861's Avatar
http://www.thumpertalk.com/forum/sho...639008&garpg=2 Here you go...way more in-depth just to idiot proof it...
USMC0861 is offline
post #9 of 10 Old 03-06-2011, 02:40 AM
Cheers Ace.
post #10 of 10 Old 12-19-2011, 06:46 PM
You'd think, as good as Honda's engines are and how long they last, that they could design a durable timing chain tensioner, not just for the XX, but everything they make with chain driven cams. My S2000 eats TCT's every 35-40K at $170 a pop. Don't feel bad. They make an aftermarket modded one for my car also that supposedly fixes it, but I've never bought one since the last OEM one I installed has lasted so far. Note to Honda: Your TCT's need to be as good as the rest of the engine.....
S2K_Driver is offline
