Adding Front Fenders - Club700XX - Honda TRX700XX Forum
post #1 of 3 Old 02-06-2011, 12:20 AM Thread Starter
duravette's Avatar
I got tired of getting mud sprayed up in my face. So I fixed it. I added the front fenders off a Cam-Am DS650. After a lot of head scratching. I was able to fabricate some mounting brackets to the front knuckles so the fenders would turn with the tires. The brackets mount between the upper and lower ball joints then over to the tie rod end. It also has a mounting tab so you can bolt the fender on and off. I cut off the old mounting point from the DS fender and added a flat mounting plate to it.
Hope is might give you guys some ideas to keep the mud out of your eyes.
I've had them for over a year now and there are still working great.
Here are some photos
http://s476.photobucket.com/albums/r...ont%20Fenders/
2008 Honda 700xx
-CP Piston 12:1 & Web Stage 2 Cam
-13t Sprocket
-Trail Tech Vapor
-Trail Tech HI-Rise Bar Clamp
-PRM Front Bumper
-PCV w/autotune
-Two Brothers slip on
-Reverse Rev Limiter Removed
-Reverse Lever Located to Handle Bars
-Warn 1500 lb Winch
duravette is offline
post #2 of 3 Old 02-06-2011, 08:29 AM
nash has that set up too i believe.
post #3 of 3 Old 02-06-2011, 04:19 PM
thats a great idea i dont like being slapped in the face either, vendors need to put this on the to do list!
FAT-T 88 is offline
