HID Headlight Install!!! (Your next mod!) - Page 2 - Club700XX - Honda TRX700XX Forum
post #11 of 192 Old 04-26-2009, 11:46 PM
fooleo's Avatar
Got 'em hooked up, turned power on, flipped the switch...they're on, then......POP!! F%$#!! What happened?! Checked the bulbs (look okay). Check voltage (none at the new plugs). Check voltage at the stock plug (nothing). Fuses... Where the hell are the FUSES?!
Just an FYI for others: I had to upgrade my 10Amp to a 15Amp for the additional draw from the HIDs.
Problem solved...crisis averted....Carry on Pvt. Pyle
Stock Lights:
New HID 8000K:
FOOLEO - 260lbs of pure attitude
'08 700xx: 2-Bros Slip-On, Renthal Bars, DG Nerfs, UNI Filter, 13T sprocket, HMF Programmer, 22" RAZRs Front & Back, ASV Levers (Red)
fooleo is offline
post #12 of 192 Old 04-27-2009, 12:03 AM Thread Starter
Yep! I had the same thing happen to mine! They look awesome, don't they?! Take it out in the street and see how far you can see, you might want to aim your headlight down a little bit, I did.
Yep, fuses are next to the battery under the seat and under the rubber cover thingy
post #13 of 192 Old 04-27-2009, 06:43 AM
Wow! That is pimp!
post #14 of 192 Old 05-01-2009, 03:10 PM
I really like the looks of the HID setup...I don't do a lot of riding at night, but I'm going to do the swap anyways...Thanks for the guide, tips, and the link to the stuff on ebay!
bkabner is offline
post #15 of 192 Old 05-03-2009, 03:25 AM
tomkat's Avatar
Jeff, im clueless about HID's. why did you choose the H6M bulb?
Fooleo, what bulb did you choose with the 8K?
tomkat is offline
post #16 of 192 Old 05-03-2009, 07:46 AM
H6M refers to the base of the bulb, Its a description of what housing it fits in. Fooleo bulb is a H6M also. The 8K is the bulb color. The higher the number the less usable light the bulb puts out. A 4K bulb is the brightest and most natural color, 8k bulbs have a blue tint with less visibility and a 10k would be purple in color and wreck you into a tree when night riding from low illumination.
post #17 of 192 Old 05-03-2009, 10:09 AM
tomkat's Avatar
Thanks smooth.
<------- will not b wrecking n2 a tree with purple lights lol
Made an offer on ebay, hope he takes it.
tomkat is offline
post #18 of 192 Old 05-05-2009, 12:29 PM Thread Starter
I think the perfect bulb is a 6k, but thats just me. I like BARELY blue tint, looks very high end. If the 4300k is brighter than the 6k... i'm glad I got 6k, cause these things are retarded bright! I'm hoping to have night ride video soon!
post #19 of 192 Old 05-05-2009, 08:02 PM
which was the fuse switched out? the 10 in the center or on the side? or both????
post #20 of 192 Old 05-05-2009, 08:03 PM Thread Starter
The one that blows lol
its only one fuse thats a 10, i put a 15 in mine i think. I forget which one it is.
