HID Headlight Install!!! (Your next mod!) - Page 3 - Club700XX - Honda TRX700XX Forum
post #21 of 192 Old 05-05-2009, 09:29 PM
theres actually two in mine... in the center, 30,15,15,10.... and on the side 30,15,10
post #22 of 192 Old 05-06-2009, 11:54 AM
fooleo's Avatar
I may be wrong, but those on the side are spares. At least mine were. There's only 3 or 4 fuses, only one of which is the 10amp. Switch it with the spare 15 and you're golden.
FOOLEO - 260lbs of pure attitude
'08 700xx: 2-Bros Slip-On, Renthal Bars, DG Nerfs, UNI Filter, 13T sprocket, HMF Programmer, 22" RAZRs Front & Back, ASV Levers (Red)
fooleo is offline
post #23 of 192 Old 07-03-2009, 01:28 PM
hey to the guys that hav done the hid mod how hard is the wiring and the actual fitment of the slims?>
smokindw is offline
post #24 of 192 Old 07-03-2009, 01:29 PM Thread Starter
Piece of cake. I HIGHLY recommend soldering them though. I used butt connectors and sometimes they flicker.
post #25 of 192 Old 07-05-2009, 03:17 AM
did you go with the bi-zenon bulb so you still have hi and lo beams or just single stage?
post #26 of 192 Old 07-05-2009, 11:04 AM Thread Starter
I just did the single stage.
post #27 of 192 Old 07-05-2009, 12:48 PM
Cool i think thas the way to go there bright enough as is dont need hi and lo really
post #28 of 192 Old 07-09-2009, 04:32 AM
I always use bi-zenon bulbs myself.
daniel86 is offline
post #29 of 192 Old 07-10-2009, 01:41 AM
yes those are what i have in my truck and thy work very well also.
post #30 of 192 Old 10-08-2009, 10:30 PM
noticed ur rims were fu**ed up just like everyone elses. what was honda thinkin using aluminum foil haha
Red700xx is offline
