$25 LED 55 watts install - Club700XX - Honda TRX700XX Forum
post #1 of 9 Old 05-07-2013, 08:29 PM Thread Starter
Quoted: 6 Post(s)
Dirtwheels had a $400 Trail Tech 75watt LED kit on a Honda 400EX. Got me thinking about putting one on the 700. So at Walmart saw a pair of Off Road LED lights. Waterproof/ rugged ($18) then Lowes for a 10" steel bracket. Cut the bracket in half. Mounted to the shocks like the 400 picture and I'm hoping for the best! The light makes a difference, but I haven't ridden it to see how well it holds up. For $25 and some time, I have nothing to lose and $375 to gain.
djbleach is offline
post #2 of 9 Old 05-08-2013, 12:23 AM
nice i would never pay 400 for them trail techs i saw that too ,good job on your deal and on a drunken night i sure would hate for it if i had those 400 trail techs would be destroyed id rather red neck it ,mount a 10million candlepower spot light to it butthe bulb prolly couldnt take too many jars and impacts,let us know how they hold up after you ride a few times.
post #3 of 9 Old 03-15-2014, 09:48 PM
700xxx's Avatar
if I have the hid kit wired into the low beam could I wire these into the high beam and not have to add another switch??
700xxx is offline
post #4 of 9 Old 03-15-2014, 10:57 PM
nacho's Avatar
Quoted: 11 Post(s)
That's pretty cool. How do you have them wired? Did you tap into the harness, or did you go to the battery?
TRX700XX
KFX700
TRX250EX
85 ATC250R
nacho is offline
post #5 of 9 Old 03-17-2014, 04:15 PM
Does it state how many lumens the led lights are ?
rappey is offline
post #6 of 9 Old 03-17-2014, 06:45 PM
yeah that all find and dandy but this cat hasnt been on here on almost a year and we never got a report on how it worked ? personally i think it wouldnt hold up to my riding style!
post #7 of 9 Old 03-19-2014, 07:36 PM Thread Starter
Quoted: 6 Post(s)
Sorry guys. I haven't been checking this site out.
The lights have held out. The are "cracked" but it's not from the outside. I think what happened is the bulb gets hot on the inside and when water/mud cooled down the glass/plastic it created the "crack" look.
I used them on our last trip to Hatfield McCoys and they were a great help. We rode at night and it gave me much more light for $25 bucks.
I've got them hooked up straight to the battery with a fuse in line.
So far there hasn't been a problem. Just remember to cut them off or you'd run the battery down.
I had thought about taken them off, but they still work. If one or both burn out or bust, I'd either take them off or get another set.
djbleach is offline
post #8 of 9 Old 03-19-2014, 08:02 PM
appreciate the feedback for 25 dollar you cant go wrong!
post #9 of 9 Old 04-14-2015, 08:32 AM
Quoted: 13 Post(s)
xtra lights
how many amps will a 700xx take care of , if wired into the low or high beams ? that way it could be controlled w/ the stock light switch. what kind of bulbs to run this way ? just curious------bob
famous bob is offline
