help me out - Club700XX - Honda TRX700XX Forum
post #1 of 11 Old 02-08-2010, 11:28 AM Thread Starter
help me out
Wut up i just got a 700xx like about 2 months ago i love the bike, the speed, handeling, even the way it looks. i have mine completely stock i clocked mine on a hand held gps and its hitting 80.6 mph, i do ride alot of trails but mostly streets theres not much terrain in miami lol. I wanted to know what does anyone reccomend for more top speed.???
Ferndawg is offline
post #2 of 11 Old 02-08-2010, 11:44 AM
I'm stock too but from what I read here I'd say go big 3(Intake, programmer and full exhaust) and change your sprockets around. The big 3 would be for the power to turn the sprockets for top end. I believe you want to go bigger on the front sprocket and smaller for the rear. You might want to try changing the front sprocket to a 15t, thats one higher than stock. Order the front sprocket for the 450r, its the same as the 700xx. Hope this helps.
post #3 of 11 Old 02-08-2010, 01:12 PM
Besides the big 3 to add power, you could also run either a 15t front sprocket OR a taller rear tire. I'd say one or the other and NOT both as you said you also do trails.
post #4 of 11 Old 02-08-2010, 02:38 PM
do the big 3(full pipe, airfilter,and fuel controler)
after that a alba stage 2 with a bored tb should give u the power for a 15t front sproket
post #5 of 11 Old 02-08-2010, 02:45 PM
EHS/B 3 kit and 15t sprocket.
post #6 of 11 Old 02-08-2010, 04:37 PM Thread Starter
If i just put on the 15t sprocket on the front do i have to change the back one and will my stock 700xx beable to pull that 15t sprocket????
Ferndawg is offline
post #7 of 11 Old 02-08-2010, 05:05 PM
Do not put a 15t on a stock or big 3 bike. A stock bike cannot pull to the top of fifth with a 14t. A big3 bike will get you to the top of fifth with a 14t and top out at 87mph. The only reasoning I could see putting a 15t wouldn't be for top end but to merely lower rpm's while your cruising the streets. Doing this is going to hurt you in the trails though. I'm a bit anti-15t but fact is a 15t will hurt performance if the motor isn't built.
post #8 of 11 Old 02-08-2010, 05:48 PM
phucknutz's Avatar
smooth is correct, but I run a 15 for the desert, and a 14 in the woods. My bike is 56hp at the rear wheels. serious engine work, more to come
Big Kidz Racing
Sponsors:
EHS Racing
Barker's Performance
Houser Racing
On The Trail TV
West Virginia ATV Tours
Hinsen Clutch Components
KBC Helmets
Hiper Racing Wheels
Member:
Score International
Best in the Desert
phucknutz is offline
post #9 of 11 Old 02-11-2010, 01:14 PM
kennyg700xx's Avatar
If you don't want to build your engine, I would simply go to a 24 or 25 inch rear tire.
2008 honda700xx
2007 honda250ex(wifes)
2009 FORD F150 supercab
kennyg700xx is offline
post #10 of 11 Old 02-11-2010, 02:35 PM
Nasty700xx's Avatar
Please explain what you mean. I had a 15t with the "big 3" and I got it off the limiter in 5th. I have seen it posted before and people might like a better understanding of what you mean.
Nasty 700xx
Barker performance exhaust
EHS racing fuel programmer
EHS racing air box lid
Hiper beadlocks
Pro taper fat bars
IMS fuel tank
DG full skids
Precision steering dampner
Hinson Clutch
Moose dual gasser throttle
DG fat nerf bars
DG fat pro V front bumper
Powermadd hand guards
ASV C5 brake/clutch levers
Nasty700xx is offline
