Oil pump failure - Club700XX - Honda TRX700XX Forum
post #1 of 3 Old 05-19-2018, 01:25 AM Thread Starter
Oil pump failure
My oil pump on my xx failed, is this a common problem on the xx and how could i prevented this?
Jan Nieuwoudt is offline
post #2 of 3 Old 05-19-2018, 02:11 AM
Quoted: 144 Post(s)
that can be very bad . oil pumps have very close tolerances. if deep scratches happen in them then oil does not get pushed ,and when one considers that the psi is only near 5 psi (not very much) any loss of lube will get you a catastrophic failure.
cataway is offline
post #3 of 3 Old 05-19-2018, 10:02 PM
OEM
Is the motor fine? How did you find out it failed? Maybe you installed the filter the wrong way. Luckily this is one of the few quads to have it on the outside not within the cases.
Sent from my SM-N900V using Tapatalk
OEM is offline
