Hi. I'm from Albuquerque NM and I recently bought a used 2008 TRX 700xx. - Page 2 - Club700XX - Honda TRX700XX Forum
post #11 of 13 Old 09-20-2018, 05:57 AM Thread Starter
I just wanted to thank you guys for your help. Finally got the bike fixed. So believe it or not my battery showed 13.6 volts and a full charge when I checked it. I took it to a car parts store to check battery and they said it was fine. After 2 weeks of trouble shooting I finally gave in and went to a battery store to by a battery. I asked them to check it and they said it was fine, but then the added a load test and found that the battery had a full charge but was putting out 0 cranking amps..... finally I'm out riding again. Thanks again.....
Vincentsanchez7705 is offline
post #12 of 13 Old 09-20-2018, 08:48 AM
/CUDA's Avatar
Quoted: 27 Post(s)
Originally Posted by vincentsanchez7705 View Post
i just wanted to thank you guys for your help. Finally got the bike fixed. So believe it or not my battery showed 13.6 volts and a full charge when i checked it. I took it to a car parts store to check battery and they said it was fine. After 2 weeks of trouble shooting i finally gave in and went to a battery store to by a battery. I asked them to check it and they said it was fine, but then the added a load test and found that the battery had a full charge but was putting out 0 cranking amps..... Finally i'm out riding again. Thanks again.....
gr8 !
/CUDA is offline
post #13 of 13 Old 09-20-2018, 01:19 PM
Quoted: 255 Post(s)
Glad you are rolling agian!
