Hard starting then high idle - Club700XX - Honda TRX700XX Forum
post #1 of 29 Old 01-06-2013, 05:04 PM Thread Starter
Landis02's Avatar
Question Hard starting then high idle
New to this post so any help will be appreciated.. Anyway I've had my 08' 700xx for bout year and half now, however I jus got it back from shop bout month and half ago for a whole engine restoration... After recieving it back I rode it at least for 30 hours never getting on it just up and down the road and around the house to completely make sure it was broke in right... After feeling comfortable with it I went on a ride yesterday to Monticello with a group of friends which sucked. We would ride maybe 10 minutes then stop for bout 30.. Worst day of riding I believe I have ever had!!!! However on our last stop before heading back to the trucks I went to start it and it acted like the battery was dead so a guy had a set of jumper cables with him so we jumped it using a 350 rancher and it started right up but it idled very high like mid range I would say. We got back to the trucks and it was still idling high so I shut it off and went to start it again and it acted like battery was dead again.. Same problem still.. Battery had been on charge since and still hard to start.. Any help please!!!
Landis02 is offline
post #2 of 29 Old 01-06-2013, 05:17 PM
i dont know what it could be, if you had your engine rebuilt id take it back to whoever and let them check it if its under warranty
post #3 of 29 Old 01-06-2013, 05:19 PM Thread Starter
Landis02's Avatar
I don't think it is... Cost me $2200 and everything is all new on the inside.. I was checking on here last night and came across a post that said valves would cause that to happen
Landis02 is offline
post #4 of 29 Old 01-06-2013, 05:31 PM
Valves could be hard start, but idk about high idle. Do you have any mods on this quad?
post #5 of 29 Old 01-06-2013, 05:38 PM Thread Starter
Landis02's Avatar
Jus powerbomb header, tbr m7 exhaust and uni air filter
Landis02 is offline
post #6 of 29 Old 01-06-2013, 06:22 PM
No fuel controller, that could be acting up?
post #7 of 29 Old 01-06-2013, 07:21 PM Thread Starter
Landis02's Avatar
Would that cause it to jus start doin it tho?? I jus checked valves.. Front was .002" and exhaust was ..010" so I put them back to .006 and .008 but still hard to start like battery is dead.. Even tryin to jump it
Landis02 is offline
post #8 of 29 Old 01-06-2013, 07:22 PM Thread Starter
Landis02's Avatar
And no fuel controller that I know of?? I don't see one
Landis02 is offline
post #9 of 29 Old 01-06-2013, 07:56 PM Thread Starter
Landis02's Avatar
If you take spark plug out it turns over but with it in still acts like battery is dead
Landis02 is offline
post #10 of 29 Old 01-06-2013, 09:21 PM
If you have aftermarket exhaust and header, you should have a fuel programmer. Did you look under the seat, and in the air box area?
Did you check the volts on battery and all connections? And what did the plug look like?
Tags
high idle hard start
