2Bros Exhaust with their ECM..Backfiring - Club700XX - Honda TRX700XX Forum
post #1 of 9 Old 05-31-2009, 02:37 PM Thread Starter
Notice yesterday while riding, when I would slow down, it would pre-detonate, basically back fire on me, haven't touch their presets and notice they're most of the time in the green zone. It's more noticeable in low gear and slow speed. Have the VALE exhaust with their ECM also the Uni filter with a twist throttle.
Has anybody else seen this issue?
Thanks
post #2 of 9 Old 06-02-2009, 01:54 PM
08TRX700XX's Avatar
Send a message via AIM to 08TRX700XX
Well when I was running both of those I would ease off on the throttle to kinda slow down and take off some rpms and it would fall flat on its face and then I would punch it and it would spit and sputter then backfire and work good until I would try it again. I tried everything then I got pissed and bought that PC3 and its been fine.
2008 TRX700XX Red/Black
Two Bro's Slip On
PC3
08TRX700XX is offline
post #3 of 9 Old 06-02-2009, 02:00 PM Thread Starter
Sounds like what I might be doing next but waiting to hear some news towards the PC5 and Alba exhaust
post #4 of 9 Old 06-02-2009, 03:02 PM
Can you tell what are the settings you have, it might be that you are lean in the 1st pot, try richening 1st pot a couple of clicks.
post #5 of 9 Old 06-02-2009, 03:26 PM Thread Starter
It's factory setup which is usually runs in the green mode which should be ok but I can try to adjust it this weekend if I ride.
post #6 of 9 Old 06-02-2009, 04:56 PM
Yeah, try to set each pot how the optimizer instructions tell you for idle, mid and wide open throttle. Should make things better. Other than that make sure that the boots are ok and that there is no exhaust leak as well.
post #7 of 9 Old 06-02-2009, 05:28 PM
TRX_Sixpac_700xx's Avatar
I've had no problems like that with my 2bros and juice box, and I'm using the factory settings and UNI filter.
TRX700XX
-UNI Air Filter
-2Bros Exhaust
-2 Bros Juice Box
-13T Sprocket
-Pro Armor Fat Pegs (Black)
TRX_Sixpac_700xx is offline
post #8 of 9 Old 06-03-2009, 06:12 PM
get a PCIII or V and you wont have any more problems. I finally got rid of the "junkbox" a few weeks ago.
12 RZR XP900
bduncan1231 is offline
post #9 of 9 Old 06-03-2009, 10:00 PM
700xx crazy's Avatar
estatic
My HMF is great! Not a problem. turned the idle pot down a bit but all the others are factory settings, Helped the burp in the idle. Doesn't die anymore i love it.
700XX CRAZY
HMF Ballance slip-on
PCIII w/"BO MAP"
Outerwear Lid Mod (by me)
Trail Tech Riser
Chub Bars
HONDA Bar Pad
RAZR2 Fronts
RAZR Rears
Elephant Ear Hand Guards(LOL)
700xx crazy is offline
