Oil usage - Club700XX - Honda TRX700XX Forum
post #1 of 7 Old 06-07-2009, 09:02 PM Thread Starter
msg harmon's Avatar
Oil usage
Im just courious if anyone else has noticed oil usage on the 700xx. I check the oil each time I go out and I've noticed that I have to keep adding oil. I've found no leaks either. It just seems strange that after a tank of fuel I have to add a cup of oil. Wondering is any one else has noticed this.
The Patriotic 700xx. Invision Blaze of Glory graphics, Pro armor Dominator II bumper, DG Nerfs, Acerbis Hand Guards, Maxxis Razr Rears, Two Brothers Exhaust, P4 Power tip, Rocky Mountain Lexx EFI controller. AC six pack grab bar, GPS Mount.
(((Handicap Racing)))
msg harmon is offline
post #2 of 7 Old 06-07-2009, 09:09 PM
Same here. Plug is normal too.
post #3 of 7 Old 06-07-2009, 09:32 PM
aschuck's Avatar
same here
aschuck is offline
post #4 of 7 Old 06-07-2009, 10:31 PM
It's almost where I can't read anything on the dipstick, but like I said before it doesn't smoke when running or under load so IDK.
post #5 of 7 Old 06-08-2009, 08:50 AM
TRX_Sixpac_700xx's Avatar
If you check the oil while the engine is cold, it will show a lower reading. You should warm the engine up a little and then check the oil. If you let the engine warm up the oil becomes thinner and shows a higher reading.
TRX700XX
-UNI Air Filter
-2Bros Exhaust
-2 Bros Juice Box
-13T Sprocket
-Pro Armor Fat Pegs (Black)
TRX_Sixpac_700xx is offline
post #6 of 7 Old 06-08-2009, 09:24 AM
700xx crazy's Avatar
The owners manual says: Let it idle for 5 mins (dont snap the throttle causes it to give an inaccurate reading). If the outside temp is below 50 F, Let it idle an additional 5 mins for a total of 10 mins. Stop the engine let sit 2 to 3 mins, and then check, this is what I do before I load mine and havent had any oil issues yet, been almost a year now! Hope this helps.
700XX CRAZY
HMF Ballance slip-on
PCIII w/"BO MAP"
Outerwear Lid Mod (by me)
Trail Tech Riser
Chub Bars
HONDA Bar Pad
RAZR2 Fronts
RAZR Rears
Elephant Ear Hand Guards(LOL)
700xx crazy is offline
post #7 of 7 Old 06-08-2009, 05:49 PM
Before every ride, I follow the suggested method in the manual and it's dead on the same spot I filled it to every time. No detectable oil usage for me.
2007 Yamaha R1 Charcoal/Black
THREESVTS is offline
