Header wrap - Club700XX - Honda TRX700XX Forum
post #1 of 17 Old 06-15-2009, 08:29 AM Thread Starter
vfm2010's Avatar
Header wrap
This weekend I installed 1" header wrap to hopefully keep my leg from cooking. I will get some pics up soon and hopefully a chance to see if it works next weekend.
I ordered the wrap from Jegs.com, a 50ft roll was $20 and $9 for the stainless clamps (not sure if they are worth it, should have just bought regular clamps).
88 LT500R QUADZILLA
06 DVX400 (Son's)
06 TRX250EX (Wife's)
vfm2010 is offline
post #2 of 17 Old 06-15-2009, 09:25 AM
The only problem with header wrap is it tends to accelerate rusting of the header pipe. If you're burning your leg I take it you're not wearing riding boots?
2007 Yamaha R1 Charcoal/Black
THREESVTS is offline
post #3 of 17 Old 06-15-2009, 09:40 AM
I don't wear boots either, and I can understand the whole header wrap idea. Even through my pant legs I can feel the burn.
post #4 of 17 Old 06-15-2009, 10:15 AM Thread Starter
vfm2010's Avatar
I wear tall work boots. I am wondering if the stock can is going to be too restrictive and cause excessive heat to build up in the header, negating any gains in reducing heat.
88 LT500R QUADZILLA
06 DVX400 (Son's)
vfm2010 is offline
post #5 of 17 Old 06-15-2009, 10:21 AM
Hmmm, good question.
I think that if you were to have an aftermarket muffler and no fuel management that it would actually be hotter. If you would compare stuck muffler and an aftermarket muffler under the same conditions (assuming the fuel mixture was the same) then the temps should be about the same.
post #6 of 17 Old 06-15-2009, 08:53 PM
MFR
MFR's Avatar
I wouldn't worry about rust. Titanium and good quality stainless don't rust, and for the price of these things no one should be using cheap metal.
ALBA Stage 3 Kit,Throttle body taper-bored to 46mm, HMF Ballance Pro Full Exhaust,DYNOJET Power Comander 5, DYNOJET Auto Tune, Velocity Filter, DWT Rims, Maxxis Razr Tires.
Current
(2) 2008 TRX700XX
(1) 2008 Raptor 250
(1) KTM 505XC
Past
2004 YFZ450
2004 Raptor660
2006 RMZ450
2000 KX250
“Things may come to those who wait...but only the things left by those who hustle.” Abe Lincoln.
MFR is offline
post #7 of 17 Old 06-15-2009, 09:16 PM
700xx crazy's Avatar
I have a Ballance slip-on, and a HMF/dobeck mine feels the same as it did. Only time it bothers me is when i'm ridin the boy around the yard and i dont have my ridin boots on.
700XX CRAZY
HMF Ballance slip-on
PCIII w/"BO MAP"
Outerwear Lid Mod (by me)
Trail Tech Riser
Chub Bars
HONDA Bar Pad
RAZR2 Fronts
RAZR Rears
Elephant Ear Hand Guards(LOL)
700xx crazy is offline
post #8 of 17 Old 06-15-2009, 11:52 PM
OzLinc's Avatar
Headder wrap is not for protecting your leg (although you can use it for that) it's for purposely holding the heat in your headder.
A hot exhaust flows better. If you can find a way to hold the heat in the exhaust it will flow better and you will get better performance.
Headder wrap and ceramic coatings are all meant for this purpose. By holding in the heat they have the added advantage of not leaking heat in to it's surrounding areas like radiator hoses or your leg.
Linc
OzLinc is offline
post #9 of 17 Old 06-16-2009, 06:25 AM
I've seen so called "good" stainless rust when header wrap was used in drag cars. ATV's are in a far more severe environment when it comes to moisture. I personally would use ceramic coating before I ever would do a header wrap. It's a cleaner look, lasts nearly forever, and far surpasses the insulating value of a header wrap.
post #10 of 17 Old 06-16-2009, 04:22 PM
Had mine ceramic coated awhile back and have notice a slight heat reduction but haven't tried it with shorts, the only time so far that I've felt some heat is when I'm in a technical ride. Overall, I'm very satisfied with the coating.
