Clutch lever - Club700XX - Honda TRX700XX Forum
post #1 of 5 Old 06-22-2009, 03:24 PM Thread Starter
Clutch lever
I want to do away with the parking brake and cable.I noticed a switch on the clutch lever and presume this is for starting in gear with clutch lever in.If I remove the switch will it still start but only in neutral.
post #2 of 5 Old 06-24-2009, 09:07 PM
WhiskeyDelta's Avatar
I don't have the manual at my feet so I can't say for sure. But in my experience, if the switch is gone, you will only be able to start it in neutral. I installed a shorty shift lever but I'm still using the stock mount. Because of the shape of the lever, it doesn't make contact with the switch until I push it down then pull in. The only time I ever have to do that is if I stall it in gear or something like that. But anytime I get it off the trailer, it's in neutral and starts without me having to do anything.
And I wouldn't mind taking off the parking brake either...doesn't seem to do that much IMO. There's been several times I've been pushing it around and stuff before I realize the parking brake is on.
2008 Honda TRX700XX
DG V-Pro Front Grab Bar/HID Headlights/Flexx Handlebars/Fasst Vibration Inserts/Odi Rogue Grips/MSR Pro-Raptor Shorty Shifter/Trail Tech Vapor Computer/Trail Tech Vapor 1 1/8" Dashboard/
Velocity Racing Intake/EHS Racing Power lid/DG X2 Slip-on/
Power Commander III EFI Controller/
Skat-Trak Mohawk/Extreme on Douglas Wheels
Full set of custom 1.5" 4/110 to 4/144 Wheel Spacers/Adapters
Elka Shocks (Full Set)
DG Factory Nerfs w/Rear Nets
WhiskeyDelta is offline
post #3 of 5 Old 06-25-2009, 08:39 PM Thread Starter
Racing a 450R I always start in neutral.
post #4 of 5 Old 06-25-2009, 09:49 PM
700xx crazy's Avatar
Just wire the two wires together and she'll start any time. Just like the clutch is in! Had to do it on my 400ex switch went bad. IMO its a dumb switch anyways.
700XX CRAZY
HMF Ballance slip-on
PCIII w/"BO MAP"
Outerwear Lid Mod (by me)
Trail Tech Riser
Chub Bars
HONDA Bar Pad
RAZR2 Fronts
RAZR Rears
Elephant Ear Hand Guards(LOL)
700xx crazy is offline
post #5 of 5 Old 06-26-2009, 04:35 PM
Park break was the first thing I took off !!! its pointless,,, you have to take the rear break apart and remove the worm drive or the breaks can drag,,, I found a big rubber gromet to put in place of the park break drive
pigdog is offline
