EHS Racing Air Box Cover or just no lid?? - Club700XX - Honda TRX700XX Forum
post #1 of 14 Old 07-01-2009, 09:31 PM Thread Starter
like the title says should i spend the 130 and get the ehs or should i just run with no lid? Does the ehs really make that big of a difference and does it keep the dirt and water out?Thanks Dann
smokindw is offline
post #2 of 14 Old 07-01-2009, 09:37 PM
haha well, Ive found what Scuzz once said he found, when you run through water, it seems to run straight to the air box opening, and im sure if you have no lid, its going to go right into the filter, also, when i rode with the stock lid, my filters got packed full of mud after like 3 rides. the EHS lid basically fixed all that for me, ive had it for like 3 rides and my filter looks basically new still, and also, if your worried about the 130$ fee, they sell just the kit for $95, thats what i did, you just have to line it up and cut your own hole, and drill the holes for the bolts, it took me like 30 minutes maybe to cut the lid and put it together. worth it to me to se like 40 bucks.
but as for running without a lid, i guess it depends on what you do, i would say no if your in: Mud, water, sand, dirt trails, an race tracks even. if you ride on pavement im sure no lid would do great.
rsshelton is offline
post #3 of 14 Old 07-01-2009, 09:43 PM
700xx crazy's Avatar
I made my own it works as good or better than ehs. and it cost me about an hour worth of work and $30 smackers. Cut my lid, bought an outterwear and wahla! I'm not smart nuff to put pic's on here or I would post some. Sorry
700XX CRAZY
HMF Ballance slip-on
PCIII w/"BO MAP"
Outerwear Lid Mod (by me)
Trail Tech Riser
Chub Bars
HONDA Bar Pad
RAZR2 Fronts
RAZR Rears
Elephant Ear Hand Guards(LOL)
700xx crazy is offline
post #4 of 14 Old 07-01-2009, 10:43 PM Thread Starter
thanks guys 4 the quik info!! i decided 2 go with the complete setup for the 130, now do they do all the assembly be4 they ship the lid or do i hav 2 do the work and also how fast r they at shipping the lids out??
Thanks Dann
smokindw is offline
post #5 of 14 Old 07-02-2009, 07:30 AM
Thanks Dann
I think for $130 you get it completed to your door.
post #6 of 14 Old 07-02-2009, 07:57 AM
KCodyRN's Avatar
Send a message via AIM to KCodyRN
I'm thinking bout doin the same thing. But have also contemplated just drilling out the little one inch holes and popping in those inserts. I forget who makes em, and am too lazy to google it. But I had em on my suzuki and they made a little difference
KCodyRN is offline
post #7 of 14 Old 07-02-2009, 01:31 PM Thread Starter
yeah i hav seen them 2 but forget off the top of my head who makes them i will do alil searching later on n find out 4 u! they r a cheaper than the ehs but ppl say the ehs lid is good so im just going by word of mouth and i ordered the ehs lid lastnight
smokindw is offline
post #8 of 14 Old 07-02-2009, 02:36 PM
I think it is Uni that makes the inserts, they are a waste of money IMO and will make tuning with the EFI contoller a pain as their is no uniform airflow. I would buy an outerwears airbox cover for the raptor 700, trim it to the size of the hole you want to cut. Get a flange to use as frame, use nuts and bolts or rivets to affix it (Do it like the EHS but should be a lot cheaper).
2006 Raptor 700
My name is Iñigo Montoya, you killed my father, prepare to die!!!
post #9 of 14 Old 07-02-2009, 03:30 PM
MFR
MFR's Avatar
I am using the Velocity filter with an outerwear over it no lid. I don't ride in the mud. IMO The only thing a filtered lid does is keep mud and dirt from accumulating in the bottom of the filter box. I don't know the numbers here but I think I have more surface area on my air filter for the engine to breath than Than a closed lid with a smaller filter built into the lid. I just don't see it as a performance advantage. it still chokes the air flow down. If you choose to run a filtered lid why have a filter in the box?
ALBA Stage 3 Kit,Throttle body taper-bored to 46mm, HMF Ballance Pro Full Exhaust,DYNOJET Power Comander 5, DYNOJET Auto Tune, Velocity Filter, DWT Rims, Maxxis Razr Tires.
Current
(2) 2008 TRX700XX
(1) 2008 Raptor 250
(1) KTM 505XC
Past
2004 YFZ450
2004 Raptor660
2006 RMZ450
2000 KX250
“Things may come to those who wait...but only the things left by those who hustle.” Abe Lincoln.
MFR is offline
post #10 of 14 Old 07-02-2009, 03:48 PM
I'll have to show you what fine silica dust looks like embedded in my filter even with the lid. The EHS lid keeps the other garbage out of my filter.
