oil cooler fan?? - Club700XX - Honda TRX700XX Forum
post #1 of 5 Old 07-08-2009, 01:26 PM Thread Starter
oil cooler fan??
Hey how does the fan work on the 700? I have had my XX pretty hot and i havent ever noticed the fan com on yet, does it still run with the bike off but with the key turned to the on position? i know that i have had her hot enough 2 turn on, i just am starting 2 think that it might not be hooked up or maybe there was a cut wire or something?
smokindw is offline
post #2 of 5 Old 07-08-2009, 07:03 PM
It's a radiator fan for the engine coolant, not an oil cooler. It should come on when the coolant temp reaches its preset spot. When I ride if the outside temp is over 85 the fan cycles on and off a lot if I'm in the woods with the technical stuff going slow. If I have some space to open it up and get some air flow into the air scoops, it doesn't come on as much. If the fan is on and you turn the key to the off position it'll go off. But if you turn it back on and not start the engine it'll come back on until it cools down enough to get below the set temp.
2007 Yamaha R1 Charcoal/Black
THREESVTS is offline
post #3 of 5 Old 07-08-2009, 09:50 PM Thread Starter
thanx buddy i knew it was the rad cooler fan i just am lazy when it coms 2 typing~ guess 2 much of the textin slang makin me lazy! butv 2 the point my fan has never cam on yet that i know of and there has been a couple of times when its been over 90 here and when im ridin in the woods jammon 1-3 gear and i cut the engine off wit the kill switch and the key still in the on pos it still hasnt cam on and i know that the bike is runnin hot enough 4 it to be on!!
smokindw is offline
post #4 of 5 Old 07-08-2009, 11:53 PM
KCodyRN's Avatar
Send a message via AIM to KCodyRN
Make sure the kill switch is in the middle, as if you're going to start your bike, then turn the key. The 4 lights up top should light up and if the bike is hot, the fan will run even if the engine is not started
Current Ride:
2008 TRX700xx
~ Modquad Intake with K&N Filter ~ EHS Racing Lid ~ Pro Armor Nerf Bars ~ FMF 4.1 exhaust with Powerbomb header
Past Rides:
1992 Suzuki DR350
1975 Kawasaki KE175
KCodyRN is offline
post #5 of 5 Old 07-09-2009, 04:34 AM
Yeah these do get quite hot with the proper cooling.
daniel86 is offline
