dyno test results - Club700XX - Honda TRX700XX Forum
post #1 of 6 Old 07-19-2009, 03:18 AM Thread Starter
dyno test results
got her dynoed today not to sure on the numbers seems a little low tell me what yall think.
post #2 of 6 Old 07-19-2009, 08:57 AM
Is the temperature correct on there? It says 101.56! That's blistering hot. If it's correct there's a bit of HP lost just to that alone.
2007 Yamaha R1 Charcoal/Black
THREESVTS is offline
post #3 of 6 Old 07-19-2009, 11:10 AM
TRX_Sixpac_700xx's Avatar
That seems quite low. Stock max rwhp should be about 40-43.
TRX700XX
-UNI Air Filter
-2Bros Exhaust
-2 Bros Juice Box
-13T Sprocket
-Pro Armor Fat Pegs (Black)
TRX_Sixpac_700xx is offline
post #4 of 6 Old 07-19-2009, 12:13 PM Thread Starter
that's a little low to it was about 109 yesterday. Lol but yeah it was hot not sure if my programer is right
post #5 of 6 Old 07-19-2009, 02:21 PM
VelociRaptor's Avatar
I see the CF(correction factor) is SAE so then yes its all corrected. Not all dynos read the same even being the same brand and type. Tire type, tire pressures, placement on the rollers all play a part. What you need is something to compare it to thats been on that dyno, like a Raptor or 450 of some sort. Then it would tell the tale.
Bo White
205-886-7043
VelociRaptor is offline
post #6 of 6 Old 07-19-2009, 03:54 PM Thread Starter
they compared it to hondas 650 dirt bike and it was a little higher than that. this test was a free one so im gonna go it one from the other shop just to see also
