Valve Adjustments - Club700XX - Honda TRX700XX Forum
post #1 of 8 Old 08-03-2009, 09:13 AM Thread Starter
Valve Adjustments
How hard is this adjustment, have done it on my 400EX numerous times which was pretty simple but from I saw last night, I basically need to take all the front plastic and gas tank off just to have access to the top end which of course it's not that hard to do but more time consuming than anything else.
Has anybody had to adjust their valves as of yet? When should you actually need to adjust them, on my 400 EX I used to do it when I could hear them clicking but with this engine and exhaust, it's hard to tell.
Thank you
post #2 of 8 Old 08-03-2009, 09:58 AM
Banned
dirtwheels says adjust your valves every 20 hrs of riding for a sport quad, i have not done it yet and i have over that... id say check it once in spring once half way threw the summer and once going into or end of fall
the_hawk is offline
post #3 of 8 Old 08-03-2009, 10:47 AM
Chrisj's Avatar
I'm around 180hr and haven't touched them.
Chrisj is offline
post #4 of 8 Old 08-03-2009, 10:49 AM
Same here. I ride the piss out of mine, but I change the oil as often as I wash it. (after every ride)
post #5 of 8 Old 08-03-2009, 11:32 AM Thread Starter
Cool! Then I won't bother with them till this winter, thanks for the info
post #6 of 8 Old 08-04-2009, 01:07 PM
You are supposed to check the valve lash after 25 hours if I remember correctly. My intakes were loose while the exhausts were good. Its not a very involved process. It might take you about an hour longer than on your 400ex the first time.
12 RZR XP900
bduncan1231 is offline
post #7 of 8 Old 08-04-2009, 03:50 PM Thread Starter
Mine is about 20 hours and usually I can tell by the sound but with this exhaust, it's hard to hear. I might still do it since I'll be doing some mileage in a couple of weeks and want everything to be a-ok
post #8 of 8 Old 08-09-2009, 09:51 AM Thread Starter
Well! Took almost everything apart then realized that I can not take the plastic cover on top of the engine due to the evaporation tube which must be depressurize prior of removing which if I'm not wrong, need to do that prior of taken the crap off so I decided to leave it and will just bring it in once I come back from Maine.
