Battery change !! - Club700XX - Honda TRX700XX Forum
 1Likes
  • 1 Post By Luecker
post #1 of 8 Old 03-24-2014, 06:10 PM Thread Starter
Quoted: 33 Post(s)
Battery change !!
I am replacing my stock battery with an Anti-Gravity 12 cell oem case that I got off ebay for $160 shipped. (retail is $220)
There is a significant weight difference. I haven't wieghed the stock battery yet.
Here is a link to the same battery I bought. Listing says 10 cell but it is actually a 12 cell. (on website they have 4, 8, 12, 16 and 20 cell battery's).
http://www.ebay.com/itm/Antigravity-...beda59&vxp=mtr
Battery would be easier to remove/install if they didn't put the seat mount directly over the top of it.
Luecker is offline
post #2 of 8 Old 03-24-2014, 07:16 PM
grin
yeah when my oem goes out thats the way i am going too . you save around 6 poundsi believe, the hell with them old heavy oems, heck i switched to lithium on my cordless work tools and the batteries are way lighter!
post #3 of 8 Old 03-31-2014, 08:56 PM
Be careful with the lithium batteries , if you leave the Key on one time over night those lithium batteries are done, those batteries are meant to have a Battery management system to cut off the electrical load if the cell voltage drops below a pre set voltage , like your cordless tool or RC toys they don't slow down or slowly lose power they just quit working until you charge them again , that system is not on our atv's electrical systems , they will work but you have to really be good about turning the key off. good luck
drtrider145 is offline
post #4 of 8 Old 04-01-2014, 08:33 PM
Jmm24's Avatar
Let us know how you like it. I thought about getting the CV4 battery. It's supposed to be 6-8 pounds lighter than oems. You really can't charge them with a normal charger though. That's why I haven't gotten one, the charger that they make special for the CV4 was like 100 bucks extra
Jmm24 is offline
post #5 of 8 Old 04-02-2014, 11:26 AM Thread Starter
Quoted: 33 Post(s)
I weighed the stock battery yesterday. 6 lbs 14 oz. New battery specs say it weighs 2lbs 4 ozs. So a savings of about 4.5lbs.
I bought it for the extra cranking amps and the lighter weight is a bonus.
I think the anti-gravity battery charger is $65.
Luecker is offline
post #6 of 8 Old 05-08-2016, 06:12 AM
blakjak619's Avatar
Quoted: 35 Post(s)
How's the Anti-Gravity charger working out for you? I want to upgrade my battery for more lighting capacity and and AG seems like the way to go
blakjak619 is offline
post #7 of 8 Old 05-08-2016, 08:44 AM Thread Starter
Quoted: 33 Post(s)
It's been working great. Only issue I have had is when I removed it to rebuild my top end, the negative battery cable cracked the corner of the case. I sent it back to anti-gravity and they tested the cells and re-cases it and sent it back.
Starts up good even with the stage 3 hot cams and higher compression. I run HID bulbs and am going to add some Black Knight LED's soon. (14" bar and 2 pods). Hopefully they are still have the special when I have some extra money.
blakjak619 likes this.
Luecker is offline
post #8 of 8 Old 05-08-2016, 03:18 PM
blakjak619's Avatar
Quoted: 35 Post(s)
The deal is still active and will be for a while. You will not be disappointed with this setup it's one of the best bang for your buck deals out there. Kyle can even do custom lens and strobe setups too. I run the (14" bar and 2 pod) setup but want to upgrade to (2) 14" bars with flash and strobe. I'll get a custom removable light rack for the bars then run 1 pod mounted low in the frame and thinking of a way to mount the other pod in the headlight housing. I'm even thinking of running 2 AG batteries. 1 regular style to replace the OEM and one of the small case batteries to run lights only.
