Installed a LED light in my front bumper - Club700XX - Honda TRX700XX Forum
post #1 of 12 Old 03-27-2014, 08:13 PM Thread Starter
ahfunaki's Avatar
Quoted: 7 Post(s)
Well on my last quad I had a 2 LED headlight mounted up by the handlebars. When I got the XX I knew I wanted to add LEDs of some sort as they are so much better than standard halogen bulbs. I knew I didn't want to mount them to the plastic.
Well when I purchased the AC racing bumper, I mainly purchased it because it was really cheap on eBay. And because I wanted something black. Little did I know it would be the perfect spot to put an LED light.
I put it on a switch so I could run it without the ignition being turned on.
So after some cutting and wiring here it is:
Motoworks SR4 Full Exhaust | Motoworks FMI | Custom Outerwears Airbox Lid | Uni Air Filter | Houser +1 Steering Stem | Houser Bar Clamp | Pro Taper Contour Handlebars | ODI Rogue Grips | Cycra Probend CRM's | AC Racing Blackline Front Bumper | AC Racing Nerfs | Honda Racing A-Arm Guards | DG Baja Full Skid | Black ITP Baja Fronts | Black ITP T-9 Pro Series Rears | GBC XC Master Tires | L8ton Racing 11/16 Pro Sway Bar | LED Bulbs | 10" LED Light Bar
ahfunaki is offline
post #2 of 12 Old 03-28-2014, 05:46 AM
Wow that looks great, and really throws the light out there that's for sure!
post #3 of 12 Old 03-28-2014, 07:53 AM
Jmm24's Avatar
I like the placement alot. One of the cleanest I've seen yet!!
Jmm24 is offline
post #4 of 12 Old 03-28-2014, 10:20 AM
Wow, thats pretty impressive.. How many watts are they?
rappey is offline
post #5 of 12 Old 03-28-2014, 12:45 PM
ahfunaki,
Nice installation. Make a very useful addition to the factory lights. Thanks for the show-n-tell.
post #6 of 12 Old 03-28-2014, 02:01 PM
nice! is it a sealed unit? after you submerge it a couple of times let us know how it held up.
post #7 of 12 Old 03-28-2014, 10:50 PM Thread Starter
ahfunaki's Avatar
Quoted: 7 Post(s)
18W according to the seller.
Will do! I might actually put some extra sealant around the edges of the lens still. Not sure...
Thanks for all the comments!
ahfunaki is offline
post #8 of 12 Old 07-02-2015, 11:53 PM Thread Starter
ahfunaki's Avatar
Quoted: 7 Post(s)
Bumping up an older thread...
I decided I wanted even more light!
ahfunaki is offline
post #9 of 12 Old 07-03-2015, 07:18 PM
Amerikanzero's Avatar
Quoted: 22 Post(s)
How well do those work mounted on you bumper like that? I would think that vibration would make it difficult to keep the beams nice and steady.
Amerikanzero is offline
post #10 of 12 Old 07-04-2015, 01:59 PM Thread Starter
ahfunaki's Avatar
Quoted: 7 Post(s)
I haven't had any issues so far. The light is so spread out it's not like it's really focusing on one area. It just lights up everything in front of you.
Hopefully I'll have some footage from a GoPro to put up in the near future while riding at night.
ahfunaki is offline
