11:1 piston mod - Club700XX - Honda TRX700XX Forum
post #1 of 29 Old 08-20-2009, 03:29 PM Thread Starter
Banned
11:1 piston mod
what all has to be done to use this piston ? would the electric stator still work ?
after the mod is done what will be its advantages ? and lastly is the mod a reliable mod ? i was told at a local store once you start changing cams and all that your reliablity starts to go to sh*t
the_hawk is offline
post #2 of 29 Old 08-20-2009, 03:32 PM
VelociRaptor's Avatar
Definately not true on durability, 11:1 is just as durable as the stock "10:1"
The starter would probably be fine with 14:1 much less 11:1. The gain in power from going from 10:1 to 11:1 is 3%, swapping the piston is pretty easy.
Bo White
205-886-7043
VelociRaptor is offline
post #3 of 29 Old 08-20-2009, 03:50 PM
Wow, 3% doesn't even seem worth the hassle
post #4 of 29 Old 08-20-2009, 05:55 PM
vfm2010's Avatar
That's about 6 more ponies for less than the price of an aftermarket exhaust that will net you about the same.
88 LT500R QUADZILLA
06 DVX400 (Son's)
06 TRX250EX (Wife's)
vfm2010 is offline
post #5 of 29 Old 08-20-2009, 06:33 PM
But you would be cooler
post #6 of 29 Old 08-20-2009, 06:54 PM
Lets say your XX has 46whp, wouldn't that mean your gain of 3% would only be 1.38hp? I don't see where 6hp is coming from. Another thing, if you're upgrading the piston wouldn't you need to go aftermarket with the exhaust anyways. I would imagine that would be the best route. I'm not trying to be a dick, just trying to figure these numbers out.
post #7 of 29 Old 08-20-2009, 07:04 PM
Yea.... I thought the same thing. 3% gain that gives you 6hp would mean that your bike already had 200hp before the upgrade. One of the two numbers aren't correct.
Atlanta 700xx is offline
post #8 of 29 Old 08-20-2009, 07:15 PM
46whp x 3% or .03 = a gain of 1.38hp. In my opinion it just doesn't seem worth the tear down. Someone slap my pee pee if I'm wrong here. lol
post #9 of 29 Old 08-20-2009, 07:44 PM
Yeah but, like, a cam *and* a 11:1 piston = a bazillion HP right?
Maybe I did my math wrong.
post #10 of 29 Old 08-20-2009, 07:53 PM Thread Starter
Banned
well befor this all gets out of hand....... is the piston worth the buy or not ? would i need to bore out if i did wanna do it or is it "plug and play"
the_hawk is offline
