Vapor Tach Signals???????? - Club700XX - Honda TRX700XX Forum
post #1 of 3 Old 08-25-2009, 05:54 PM Thread Starter
blkcruzer's Avatar
I installed the vapor and I am having a heck of a time with the Tach signal wiring. I tapped right onto the green wire on the coil and that didn't work right, so I called trail tech, and they said add a 600k resistor and try again. Still didn't work, so today I tried wrapping the signal wire onto the plug wire, I tried 7 wraps and it was super bouncy, so the directions say less wraps, so i tried 5 wraps and it wouldn't read over 4000 rpm.
Do any of you have pics of your installs, or some pointers of what I might be doing wrong??
Thanks
Jason
blkcruzer is offline
post #2 of 3 Old 08-25-2009, 09:25 PM
What is your PPE or PPT or something like that setting on the vapor?
2006 Raptor 700
post #3 of 3 Old 08-26-2009, 12:34 AM Thread Starter
blkcruzer's Avatar
It is ppr, pulse per revolution, and it is set at 1 like the guy from trail tech said it should be.
Jason
