Power Commander V And Auto Tune - Club700XX - Honda TRX700XX Forum
post #1 of 13 Old 08-26-2009, 01:40 PM Thread Starter
has anyone checked this out if you get the power commander v you can get the auto tune accessory the will self tune your bike so no more changing settings from place to place. look pretty sweet but about $600 for both. does anyone have this yet?
post #2 of 13 Old 08-26-2009, 07:50 PM
post #3 of 13 Old 08-26-2009, 09:34 PM
vfm2010's Avatar
halfway there, just gotta get the autotune. I was holding out for Alba's exhaust with the O2 bung, that's all up in the air now.
88 LT500R QUADZILLA
06 DVX400 (Son's)
06 TRX250EX (Wife's)
vfm2010 is offline
post #4 of 13 Old 08-26-2009, 11:14 PM Thread Starter
when i looked it up it only shows the PCV of the 09 xx's but i dont think there is a difference???
post #5 of 13 Old 08-27-2009, 09:17 AM
vfm2010's Avatar
Mines an '08 there is no difference.
88 LT500R QUADZILLA
06 DVX400 (Son's)
vfm2010 is offline
post #6 of 13 Old 09-04-2009, 10:04 AM
Anyone care to share maps?
Here's one that I modified from a map from MFR to fit my way-less-aftermarketed 700xx:
Password for zip = club700xx
https://www.club700xx.com/vb/attachme...3&d=1252076425
Keep in mind that I'm no pro at this and I haven't tested it but I will tomorrow.
post #7 of 13 Old 09-04-2009, 10:18 AM
Also, I had an issue when I tried to load MFR's map and edit it then load it to my 700xx PCV.
Here's the error I got:
Unable to send map
The map file type does not match the device.
After some quick google-ing I found this thread:
http://www.600rr.net/vb/showthread.php?t=136155
It appears there are two different versions out there....
post #8 of 13 Old 09-04-2009, 03:05 PM
vfm2010's Avatar
Gary I was looking at the map that came with the PCV for an all stock setup and was surprised that reductions were made in several spots( as much as -15 I think) and not much enrichment on the low end. Oh! yes I'm am interested swapping maps(sorry big fella I have to draw the line there tho) However I only have the maps that were on DynoJet's website. I know that the PCV has ten channel's vs. the PCIII's 9, Do you think we could overlay a PCIII map and interpolate for the extra channel?
Also any indications on how to decipher which version we may have?
88 LT500R QUADZILLA
06 DVX400 (Son's)
vfm2010 is offline
post #9 of 13 Old 09-04-2009, 03:13 PM
vfm2010's Avatar
Never mind on version question I hadn't read that post thread yet.
88 LT500R QUADZILLA
06 DVX400 (Son's)
vfm2010 is offline
post #10 of 13 Old 09-27-2009, 08:23 AM
i can send you a few maps i've been through. some where to lean for my setup and may work for yours.
