blown clutch!!! - Club700XX - Honda TRX700XX Forum
post #1 of 18 Old 08-29-2009, 02:43 PM Thread Starter
double_0_xx's Avatar
blown clutch!!!
So I have about 30 hours total, I ride trails and 14 tooth.. need to clutch a lot in order not to stall..
That said, the clutch is now slipping. I tried adjusting the lever a bit and no luck. Can you believe this at all? I was told it is not covered under warranty but I seriously think this is bs... 30 hours should not be enough to wear a clutch out.
The tech said sometimes when a new clutch goes through excessive wear a "glaze" is formed.. something about not soaking up enough oil.. but my bike has been sitting for 5 months. Maybe it is ride time to heat up and soak in oil.
Also, one thing I can also do is switch gears without engaging the clutch. I never do this but still was very easy.
Am I driving this thing wrong or something? I really dont drive hard.. I have been in a lot of mud and engaged the clutch a lot, but no more than my last bike.
So, If I do need to replace the clutch and its not warrantied, what should I replace with so this NEVER happens again in 30 hours of use.
Also the tech said 5 hour job plus parts!!! way to expensive.. .I will have to dig in myself.
Help!
double_0_xx is offline
post #2 of 18 Old 08-29-2009, 03:46 PM
wayne matlock's Avatar
You can buy a Matlock Racing clutch kit, we have been racing it for the last 5 races and we just did a 1000 mile 3 day rally race and had no problems at all. The stock clutch with our 64 HP motor would not last 200 miles. PM me and I will get you the price, it comes with plates, fibers, springs and oil recommendation.
As far as time goes it should take you less than an hour to put it in. We can change a clutch out at a race in less than five minutes.
wayne matlock is offline
post #3 of 18 Old 08-29-2009, 03:57 PM
700xx crazy's Avatar
He's nuts 5 hrs is BS! The motor has a clutch cover U dont even have to take the whole side case off, DUMB TECH just wants ur money!!!!
700XX CRAZY
HMF Ballance slip-on
PCIII w/"BO MAP"
Outerwear Lid Mod (by me)
Trail Tech Riser
Chub Bars
HONDA Bar Pad
RAZR2 Fronts
RAZR Rears
Elephant Ear Hand Guards(LOL)
700xx crazy is offline
post #4 of 18 Old 08-29-2009, 04:04 PM
post #5 of 18 Old 08-29-2009, 04:54 PM
I only use the clutch to set off and change down gears. Never to change up.
Wayne , what other special parts do you have ?
post #6 of 18 Old 08-30-2009, 08:47 AM Thread Starter
so is it as easy as popping off the cover and replacing the plates?
Also, if anyone has the pdf of a shop manual that would be great. PM me if you have any info.
post #7 of 18 Old 08-31-2009, 09:20 AM
My Honda dealer is telling me a lot of the problem is when people run Moly oil in their clutch!
Bravo XX is offline
post #8 of 18 Old 09-01-2009, 07:08 AM Thread Starter
So here is something I found on youtube for clutch replacement. How the heck does the dealer say 5 hours? Absolute BS!
I am no rocket scientist, but I would think this is a 45 min job with the correct tools.
post #9 of 18 Old 09-01-2009, 07:09 PM
OzLinc's Avatar
It's even easier and quicker than that.......tip the quad on its side and you dont even have to drop the oil.
Linc
OzLinc is offline
post #10 of 18 Old 09-01-2009, 07:10 PM Thread Starter
Linc
what about any residual "blown" pieces? It is a brilliant idea.
