Right drive inboard joint removal - Club700XX - Honda TRX700XX Forum
post #1 of 10 Old 05-29-2014, 10:15 AM Thread Starter
crying Right drive inboard joint removal
Hi to all, i'm italian and i need help for right drive shaft removal.
I read service manual page 434-435 but or i don't understand english very well or i have a something broken.....
This is my situation:
http://it.tinypic.com/r/34yee0w/8
http://it.tinypic.com/r/nzfwpd/8
I need to remove inboard joint.... please help me in easy english
Thanks
ducati82 is offline
post #2 of 10 Old 05-29-2014, 01:09 PM
Quoted: 260 Post(s)
Smack it with a big hammer and a tie-rod removal tool, or pickle fork. Let me know if you understand that, And ve sure to line up forks with bolts on brake rotor to avoid damaging rotor.
post #3 of 10 Old 05-29-2014, 01:11 PM
Quoted: 260 Post(s)
A link to my old thread....
https://www.club700xx.com/vb/showthre...+inboard+joint
post #4 of 10 Old 05-29-2014, 01:32 PM Thread Starter
Thanks very much for reply
- Where i must smack with hammer? In the joint???
- What it is tie-rod removal tool or pickle fork?
- What i must line up? I don't undestand
Sorry and thanks for help me!
ducati82 is offline
post #5 of 10 Old 05-29-2014, 01:58 PM
Quoted: 260 Post(s)
^^^^The end of the tie- rod removal tool^^^^^
^^^^ http://www.summitracing.com/parts/kt...FcpcMgodYAYAAQ ^^^^^
^^^^Align the forks of the tie-rod tool with the allen bolt heads that hold the brake rotor on, before you hit with hammer! ^^^^
no problem I hope this helps!
post #6 of 10 Old 05-29-2014, 02:27 PM
You need to force it off.. you need to drive a wedge between the rear disc and part you want to remove..
Be very carefull what you lever against!
rappey is offline
post #7 of 10 Old 05-30-2014, 04:07 PM Thread Starter
Yeaaaaah i have removed it
In Italy i cannot found spare parts so i think will buy in U.S...... which are best site??
I have TRX700XX rev.B but i found only spare parts for TRX700XX rev. A , si the same??
Thanks very much
Byeee
ducati82 is offline
post #8 of 10 Old 05-30-2014, 04:15 PM
I,ve used this site for genuine parts.. A third of the euro price !!
Im sure others on here can give even better sites?
If you look at that diagram you may need parts 2, 8 and 16 ?
http://www.hondapartshouse.com/oempa...ear-driveshaft
rappey is offline
post #9 of 10 Old 05-30-2014, 04:16 PM
Quoted: 260 Post(s)
Pm sent
sent using tappetalk!
post #10 of 10 Old 05-30-2014, 05:19 PM Thread Starter
Thanks to all!!
For the rev. what you think?? I have rev.B, and you? The spare parts are the same of rev.A?
Thankssssssssss
ducati82 is offline
