700xx de-tuned for California?? - Club700XX - Honda TRX700XX Forum
post #1 of 7 Old 09-09-2009, 01:32 PM Thread Starter
I have read elsewhere that the 700xx has been de-tuned for California taking away from the low end and mid range. Does anyone know if this is actually true??
Also, if true, would something like the PCiii correct the de-tuning?
The rumor is that Honda did this to meet California emission standards.
roadkill (yep, in California)
post #2 of 7 Old 09-09-2009, 02:29 PM
havent heard anything about that but yes exhause efi controler and intake aka the big three will get rid of and de-tuning and give you so much more
post #3 of 7 Old 09-09-2009, 02:47 PM
This is why usually bikes and quads will come a little lean from the factory, to pass emissions tests.
2006 Raptor 700
post #4 of 7 Old 09-09-2009, 04:06 PM
It is possible that there is a california version. I had an 04' VTX 1800 that was california emission,(evap. can and extra emisson crap), you could tell by a designation in the vin number but, I don't remember exactly what it was,(CA I think). They typically dynoed a little less than the 48 state versions. Good thing is all that stuff is removable without harm, just have to plug the vaccum ports where it comes off.
iowa fan is offline
post #5 of 7 Old 09-09-2009, 07:20 PM
OzLinc's Avatar
Cali is the strictest of all the States with regards to emissions. There is no Cali specific version, they (Honda) just make it legal for use in California and every other state is therefor covered. This does mean that the 700XX is quite restricted.
This is not a rumor it's fact and Honda will tell you this if you can get them on the phone. Just look up the Cali EPA site and you will see the 700XX info there.
eg: Top power on a 700XX is made with a A/F of about 13~13.5:1 but EPA demands a A/F of 14.7:1 this is quite lean. A Power Commander could fix this. There are other factors in there but this is the main one.
Linc
OzLinc is offline
post #6 of 7 Old 09-10-2009, 10:07 AM Thread Starter
Thanks all. Thats the info I needed. I found where I read that about the 700xx. It was from a media/factory intro at Dumont Dunes in California. A small part of one media review is below...
We also believe that Honda has used the programmability of the fuel injection system to de-tune TRX700 because it is a little sluggish on the bottom end and it also had a tendency to stall fairly easily at low RPMs, but sluggishness disappears at mid throttle when the 686cc engine comes alive. Honda didn’t have any comments on our findings, but we are confident that re-mapping the EFI to richen the fuel mixture will eliminate our test units low end hesitation, which was probably done to meet emission standards....."
post #7 of 7 Old 09-15-2009, 10:08 PM
Excellent find!
