Fram Ch6015 - Club700XX - Honda TRX700XX Forum
post #1 of 4 Old 09-12-2009, 07:23 PM Thread Starter
CharlieZRX's Avatar
waving Fram Ch6015
The Fram CH6015 oil filter will not fit in the TRX700XX, The side that faces the motor is not deep enought, It look's the same but it could cause alot of problems, because when you tight it up it will smash the oil filter, or cause you too strip your bolt. If any of you use a different type please tell the type and how they worked.
CharlieZRX is offline
post #2 of 4 Old 09-13-2009, 03:54 PM
I always wondered this but was always too chicken to try it out on my quad. This is why I always went with Honda's filter.
post #3 of 4 Old 09-15-2009, 10:14 PM
post #4 of 4 Old 09-17-2009, 12:06 AM
700xxx's Avatar
the GF has a 08 kawi 450r and its the exact same filter. the honda 450r and others in the TRX class are diffrent. when I got my 700xx they gave me 2 filters and when they did not fit they told me they where for the TRX line of atvs
700xxx is offline
