How do you cure the back fire - Club700XX - Honda TRX700XX Forum
post #1 of 10 Old 09-16-2009, 07:47 PM Thread Starter
How do you cure the backfire ? In tight woods riding ,sometimes it would backfire and stall.
Would like to cure this.
post #2 of 10 Old 09-16-2009, 08:58 PM
Any mods on it like exhaust, removed baffle, no lid, fuel controller? This is usually caused by a lean mixture. With more info we can help. Also note that quads are usually a bit lean from the factory to pass emissions tests, so a fuel controller (like dobeck, lexx, power commander 3 or 5) should be the 1st thing on your mod list.
2006 Raptor 700
post #3 of 10 Old 09-16-2009, 11:59 PM
700xxx's Avatar
mine does it to WITH a tuner. and I did do a plug check and its all good.
700xxx is offline
post #4 of 10 Old 09-17-2009, 06:46 AM
Banned
i got the lexx programmer and after a good ride to get things moving i almost never have a back fire any more it might back fire once all weekend of rideing
the_hawk is offline
post #5 of 10 Old 09-17-2009, 09:50 AM
X2 - sounds like you're running WAY too lean.
post #6 of 10 Old 09-17-2009, 03:49 PM Thread Starter
No mods done yet ,running stock everything.
So a programmer will cure this if I set it up a bit rich ?
post #7 of 10 Old 09-17-2009, 03:53 PM
Mine popped and farted a bit in stock form but after the dyno work with pipe, PC and airbox lid off it runs purrrrfect!
Simon Walton is offline
post #8 of 10 Old 09-17-2009, 05:29 PM
Yes, mine would do that in stock form as well - drove me nuts on climbs where I would blip the throttle.
post #9 of 10 Old 09-18-2009, 01:53 AM
Do you like Bo's tune or you "lean" tune better? Someone said something the other day that made me think I might still be running a little lean.
post #10 of 10 Old 09-18-2009, 08:48 AM
Hind sight being 20/20 I think that I may have:
1. Over oiled my air filter and the air filter oil got on my plug.
2. The rings didn't like the honda synthetic and oil was slipping past the rings.
3. The Oil filter was a K&N and it didn't let the oil lubricate correctly.
I'm not sure. I know the oil was black as shit and the plug was black as shit, and honestly I think it's on of the latter two than the map being too rich.
They say you get experience when you didn't get what you wanted.
