Slip-on, or full exhaust??? - Club700XX - Honda TRX700XX Forum
post #1 of 11 Old 10-15-2009, 08:15 PM Thread Starter
Hey guys, I'm just curious if a slip on is ok to get, or should I go with a full exhaust? I just don't want to waste my money getting a slip-on if it really doesn't do much as far as adding power, only better sound. I am looking at the HMF sport series pipe. All feedback would be greatly appreciated! Thanks I was also looking at the HMF optimizer as well. Let me know your thoughts on this please.
vyper69 is offline
post #2 of 11 Old 10-15-2009, 09:00 PM
You do get a little more performance out of a full system. But depending on your budget, that little bit extra may not be worth it. If I was you I would NOT get the HMF Optimizer. Spend a little extra and get the Power Commander 5. Much better fuel management and will automatically adjust fuel when you increase air flow.
2007 Yamaha R1 Charcoal/Black
THREESVTS is offline
post #3 of 11 Old 10-15-2009, 09:40 PM
Balling Option: Full Exhaust, PowerCommander V, Velocity Filter
Baller Option: Full Exhaust, PowerCommander & AirFilter
Best Option: Full Exhaust & PowerCommander
Better Option: Full Exhaust & Optimizer
Broke Option: Slip-on and PowerCommander
post #4 of 11 Old 10-17-2009, 11:18 AM
De700's Avatar
Hey Guys I am kind of lost with this question. I don't see a huge price difference between the 2, but Is there a huge difference between the PC 3 and PC 5.
Thanks in Advance,
CJ
De700 is offline
post #5 of 11 Old 10-17-2009, 11:39 AM
Yes, The PCV can be used with an AutoTune Module and mapping is a bit more detailed. The PCIII is fine if you don't intend on using the AutoTune Feature
post #6 of 11 Old 10-17-2009, 12:21 PM
Yeah agree with smooth1, but if you are buying the PC new then get the PC5 since they cost exactly the same. The only thing I dont agree with him is on the Velocity filter, get the Pro Design kit with K&N if you dont ride in extremely dusty conditions, if you do look for foam Pro design. Oh, and get a full system, with the slipon the gain will be minimal and it is mostly sound.
2006 Raptor 700
post #7 of 11 Old 10-17-2009, 12:27 PM
De700's Avatar
Thanks. I thought the pc5 needed another product added to it which brings the total cost to around 600. SO the only big difference is that the pc5 has a auto-tune and the PC3 would need to load 1 map at a time. Is this correct?
So if you have PC5 it would auto-tune for the condition you are riding in? Where as the PC3 you would need to load a separate map? I thought the tuning was based off of the aftermarket products you may have on the bike and not the condition of the riding area, or am I way off?
I just bought the UNI foam air filter, because I ride in coal dust a lot and didn't want any issue's.
De700 is offline
post #8 of 11 Old 10-17-2009, 01:11 PM
The PC5 can be used stand alone, One of the other members has an actual dyno'd map for it also which is a plus. Even if you use purchase the Autotune Module you would want to use a map for a quicker tune.
Tuning is based off of performance alone, not riding conditions. (excl. High Altitudes)
The uni is fine with me also, I just recommend the Velocity if you need maximum breathing capabilities.
post #9 of 11 Old 10-17-2009, 01:13 PM
De700's Avatar
Wonderful, so the only diff is the pc5 will auto tune off that map you have installed where as the PC3 will just use that map.
Thanks for all the great info
De700 is offline
post #10 of 11 Old 10-17-2009, 01:19 PM
You must purchase the Autotune Module seperately
