How many teeth on the front sprocket of a stock XX? - Club700XX - Honda TRX700XX Forum
post #1 of 9 Old 12-03-2008, 01:21 PM Thread Starter
Well? I need to know how many i need to go down a tooth.
post #2 of 9 Old 12-03-2008, 01:27 PM
14, you can get a stock 450r sprocket which is 13.
post #3 of 9 Old 12-03-2008, 01:28 PM Thread Starter
Awesome! Thanks! (for the move too) Just how much change is 1 tooth going to make? anyone have a how-to on changing the front sprocket?
post #4 of 9 Old 12-03-2008, 01:30 PM
The change will be noticable, I haven't seen anyone mention going any lower.
post #5 of 9 Old 12-03-2008, 01:49 PM Thread Starter
i'm looking to gain some low end torque so its easier to get going up a hill when you stall lol.
post #6 of 9 Old 12-03-2008, 01:52 PM
Half throttle, pop clutch and proceed sideways up hill
post #7 of 9 Old 12-03-2008, 01:58 PM Thread Starter
I eventually got frusterated with it. Rolled back down the hill and went up it in a different spot. This is my first manual clutch, so it will take some getting used to.
post #8 of 9 Old 12-10-2008, 05:13 PM
Yeah, that was my 1st complaint about my 700xx. At Red River ATV there are quite a lot of technical/rocky climbs that are even harder when you're feathering the clutch.
I had an easier time with my 400ex because I had lowered it in gearing too. Once I feel like dealing with it I'll change it. I've been riding in sand where wheel spin is kinda a good thing (with stock tires) so I haven't changed it. Wheel spin on a steep and rocky climb would get downright scary. (the throught of the 700xx crushing my brain inside of the helmet scares the bejeezus out of me too.)
post #9 of 9 Old 12-25-2008, 07:44 PM
DblXX's Avatar
Send a message via AIM to DblXX
don't hold me to this but when i had my ninja i was told that goin 1 tooth down in the front is like goin up 3 teeth on the back. so this should be a good rule of thumb if it helps.
DblXX is offline
