94db exhaust - Club700XX - Honda TRX700XX Forum
post #1 of 10 Old 10-18-2009, 05:37 PM Thread Starter
94db exhaust
Any Ideas. That the limit where I ride.
Loneranger is offline
post #2 of 10 Old 10-18-2009, 05:42 PM
Fmf Q4
post #3 of 10 Old 10-18-2009, 05:45 PM Thread Starter
Do I need a programmer if I run a aftermarket exhaust ?
post #4 of 10 Old 10-18-2009, 05:45 PM
bkelley's Avatar
The HMF Quiet Race Series should be right in that range.
Edit: Actually, looks like it's in the 96db range.
Red '05 TRX400EX:
bkelley is offline
post #5 of 10 Old 10-18-2009, 05:48 PM
With a full exhaust you absolutely need a programmer. With just a slip-on you can get by without it.
post #6 of 10 Old 10-18-2009, 05:49 PM
bkelley's Avatar
It's highly recommended.
Red '05 TRX400EX:
bkelley is offline
post #7 of 10 Old 10-18-2009, 05:51 PM
It's highly "debated"
post #8 of 10 Old 10-18-2009, 05:53 PM Thread Starter
HMF is too loud at 96db. there really strict being a private ride. Thanks smoOoth1.
post #9 of 10 Old 10-18-2009, 06:58 PM
OzLinc's Avatar
Tip......check how its measured as 94db is 96db on a Type-2 db meter. Type-2 is what is usually used.
OzLinc is offline
post #10 of 10 Old 10-18-2009, 10:18 PM
Move to Texas!
