HELP!! Wont Start!!! - Club700XX - Honda TRX700XX Forum
post #1 of 28 Old 10-19-2009, 07:13 PM Thread Starter
Ok so this morning one of my buddies wanted me to start it up so he could hear it, i have the HMF slip on and the HMF optimizer, but it start up and ran just fine and then this afternoon we got back from work and i unloaded it so he could give it a test drive well i got on it to start it and all it would do is crank and nothing else. its gettin both spark and fuel! so what could it be? Any thoughts would be greatly appreciated
08xxrider is offline
post #2 of 28 Old 10-19-2009, 07:35 PM
XCalibur's Avatar
I would check your connections on your optimizer, it just takes one cable togive you those problems.
XCalibur is offline
post #3 of 28 Old 10-19-2009, 07:54 PM Thread Starter
Everything is hooked up, i even unplugged it and plugged it back in
post #4 of 28 Old 10-19-2009, 09:26 PM
gavineli's Avatar
Check your thumb switch make sure its in the run position dont know if it will or wont crank over with it in the off i just know it wont run
gavineli is offline
post #5 of 28 Old 10-19-2009, 09:28 PM
How have you confirmed its getting spark and fuel?
post #6 of 28 Old 10-19-2009, 09:37 PM
Make sure your gas tank is not empty and the petcock is ON. Not saying you didn't check it, just basic trouble shooting. Be sure the Plug wire is properly connected to the spark plug. Another thing, I was riding and a tree branch snapped the tabs on a fuel shut off switch in the front of the quad. Its there in case you flip the atv upside down. I had to zip tie it upright. Its was swinging from the wire in front of the radiator when it happened to me.
post #7 of 28 Old 10-20-2009, 11:12 AM Thread Starter
Smo0oth1, i took the plug out and held it up against the motor, and you can smell the fuel in the pipe..
xx700xx, its got over half of a tank and i even tried it on reserve
post #8 of 28 Old 10-20-2009, 03:08 PM
skier207's Avatar
Try a shot of carb spray in the intake while cranking, to see if it farts. I know you said you saw spark but a new plug is cheap, I have seen plugs that fire when tested, but won't under compression. What is your battery voltage? Low battery voltage will cause a crank but no start on any fuel injected engine. Lastly, I would try it with the fuel optimizer disconnected.
skier207 is offline
post #9 of 28 Old 10-20-2009, 04:57 PM
post #10 of 28 Old 10-20-2009, 08:46 PM Thread Starter
I have the new E3 plug in it, its not that old.. and the battery is fine and I have already tried disconnecting the optimizer... Im takin the pipe and optimizer off tomorrow and puttin it back to stock and takin it to my local Honda shop thursday.. Still have 6 months of warranty left so why not use it!!!
