newbie questions - Club700XX - Honda TRX700XX Forum
post #1 of 12 Old 10-24-2009, 06:43 PM Thread Starter
newbie questions
ok, I am a new member and this is my first post. just recently bought my xx and love it. also agree with some of the negative reviews that people have written about, however small and fixable problems I really have not complaints other than the couple small quirks. its an overall excellent quad.
I have been researching the threads a couple days since I joined and have learned a couple of things. I also know that these questions are asked frequently but notice that there are many answers to every one of those questions.
I am going to get a complete pipe setup and tuner and air F.
#1 From what I gather the PCv is the way to go, and what I am most likely going to get. my only question to that is, must you run the o2 sensor with this? and if I read correctly the o2 sensor is and extra $200!. I donít think I would want to pay that much for a sensor (unless the added benefit of this is a ton) if that is true then would the PC3 be just as good as the PCV w/o the o2 sensor.
#2 it sounds like the two best pipe set ups are the FMF and the alba. which is better?
#3 I'll be going with a foam filter (less maintenance) is the uni filter the best to get?
#4 what aftermarket wheels (and tire size) will fit on my quad? Iíve looked at AMS sight and the itp sight. I like wheels from both manufactures but only see 10" wheels for the rear. what do I need to get for front and rear????
thanks in advance and I know these are repetitive questions but just cant seem to find the right answers
hobby10k is offline
post #2 of 12 Old 10-24-2009, 08:31 PM
Welcome aboard.
#1 I think the PC5 uses the Auto Tune witch uses the O2 sensor. I don't think that it's required to work, so a PC3 would be the same.
#2 IMO the Yoshimura is one of the best along with the Alba.
#3 UNI, UNI, UNI. Unless you want the risk of dirt getting by the filter because you forgot to clean a K&N.
#4 There are no 11" rear wheel options for us just yet. A 10" will fit the, but the mud scrapers will have to go. The front wheels are easy to find in 10" sizes.
Don't worry about the repetitive questions. If everyone only asked a question once, the site would be dead.
2007 Yamaha R1 Charcoal/Black
THREESVTS is offline
post #3 of 12 Old 10-24-2009, 11:20 PM
*from what i gather, the PCV is good if you have the extra cash and ride in different areas where you don't need to get off your quad and change your settings. I believe it adjusts itself. If you ride in one certain area for the most part, go with the PC3 or the Alba programmer
*ALBA for me. I've heard and seen the HMF in action and it's great. For me, it's just a matter of supporting those who support me... and will be running it with the matching programmer
*UNI is the way to go
* Douglas makes a wheel for the rear in 11", or if you have the cash, OMF can make some SICK wheels to your liking...
post #4 of 12 Old 10-25-2009, 01:00 AM
09RappySE's Avatar
Quoted: 16 Post(s)
The PC5 without the auto tune works just like the PCIII does and at least for the raptors is about the same price as the PCIII...so I would go with the newer technology, as far as the auto tune, it works very well, it for the most part keeps you from having to visit the dyno for a tune every time you add a new mod unless of course you do it all at once, so if you are going to do the big 3 and thats it I would not waste money getting the auto tune unless you do not have access to a dyno for tune, you can also get a few buddies together and purchase one auto tune and swap it between all your bikes, assuming they all have PC5's.
Hope this helps
734 09 Raptor
Tuned by EHS Racing 78hp 55Tq
09RappySE is offline
post #5 of 12 Old 10-25-2009, 02:19 PM Thread Starter
alright, ordered a uni filter.. are you guys heavy oiling these or light oil?
also, where is the best place to get coplete pipe kits and PCV? I cant find the pipes on the alba sight, only the engine kits.
hobby10k is offline
post #6 of 12 Old 10-25-2009, 02:45 PM
The Alba website isn't being run by them anymore... Call Alba directly and they can hook you up...
post #7 of 12 Old 10-25-2009, 06:05 PM
skier207's Avatar
I just got a PC V from 58cycles 280.95 shipped.
http://store.58cycle.com/Default.asp
If you have a 08 machine and you want the PC V you have to order one for an 09 machine. There are no differences in the two years, but Power Commander will not list it because they haven't actually tested the unit on an 08. I offered to take mine up there, they didn't even reply.
skier207 is offline
post #8 of 12 Old 10-25-2009, 07:49 PM
You dont have to use the AutoTune feature but if you do purchase it you get the O2 sensor and tuning module.
The honest answer here is any of the major name brand exhaust will perform nearly identical. It's a choice of preferred sound and looks.
The Uni gives you allot of bang for yer buck
DWT can make you some 11" wheels, No one currently stocks them in our size and bolt pattern though
Damian
post #9 of 12 Old 10-30-2009, 11:20 PM Thread Starter
header
what about the FMF mega bomb header? is it any good, and can you run it with any muffler?
also, is there anywere that has pics of the alba exhaust system? I havn't called them but just would like to know a price and see a picture.
hobby10k is offline
post #10 of 12 Old 10-31-2009, 03:10 AM
https://www.club700xx.com/vb/showthread.php?t=1483 ... bottom of the page
425 without O2 bung... 450 with...
