No Start - Club700XX - Honda TRX700XX Forum
post #1 of 5 Old 12-04-2014, 04:43 PM Thread Starter
No Start
Looking for ideas before I go tearing into the bike. I was letting bike warm up about 10 min (water temp of 190ish). When i came out of garage I bliped it from idle & it stalled. Now won't restart, if i crank on it awhile it back fires. It has plenty of gas & clean air filter.
I'm thinking its spark.
Anyone else have something similar happen & if so what was the fix?
Thanks
pswag115 is offline
post #2 of 5 Old 12-04-2014, 04:59 PM
Jmm24's Avatar
My red one did the bog/almost stall while blipping the throttle too. It also happened suddenly and seemed to be out of nowhere. Changed the spark and it was back to normal. It never happened again. Seems like a good place to start
Jmm24 is offline
post #3 of 5 Old 12-05-2014, 08:16 AM
Quoted: 251 Post(s)
Start with easy stuff 1st, double check your fuel leaver. 10 mins is about the right time it will run on whats in the fuel pump. Just a thought
post #4 of 5 Old 12-05-2014, 05:18 PM
I have had a few problems with the 700xx starting lately. One was would only turn over one revoloution of the motor at a time. Quick cure was rock the 700xx back and forth in gear , pull the clutch in and it fired up. The other was play(wiggle) the plugs under the headlight cover(red or grey nose piece) and it started.
I think the first problem was because I am running a 754cc bored and stroke motor with a stock battery.
Also one thing that springs to mind is if the battery is not fully chargedish , it spins over but not enough power to start.
post #5 of 5 Old 12-07-2014, 12:12 PM Thread Starter
Thanks for the ideas, new plug fixed it!
pswag115 is offline
