headlights for XX / stator wattage? - Club700XX - Honda TRX700XX Forum
post #1 of 33 Old 12-03-2008, 04:54 PM Thread Starter
What bulb is in the headlight? Looking for HID replacements. also, how many watts does the stock stator put out?
post #2 of 33 Old 12-03-2008, 05:13 PM
HID's draw less watts than standard bulbs
post #3 of 33 Old 12-03-2008, 05:27 PM Thread Starter
Yeah, but I need to know which bulb is in the XX so i can get the HID replacement
post #4 of 33 Old 12-03-2008, 05:52 PM
OzLinc's Avatar
Wrong........a 35w HID will pull??????? guess what.........35watts; same as stock........pretty sure its 35w.
The fact that a 35w HID globe will be brighter than a 35w Halogen has nothing to do with the amound of stator power needed. One thing a HID will do is draw alot more from the stator during start-up. Its just a fraction of a second but it can actually draw more than your stock wiring can handle.
At a guess the 700XX will have 2 x 35watt globes and a PIAA H6M would be a good cheap substitute. The H6M draws about the same wattage as stock but puts out nearly twice the lighting power.
Linc
OzLinc is offline
post #5 of 33 Old 12-03-2008, 06:57 PM
Actually I'm not but may could have been more clear about it. Of course a 35W HID will draw 35W but the lumens will be much much higher. So he could actually get a HID kit that draws less power but is much brighter. The bit on the amp draw is a bit overboard also since we are being technical about it. If the stock bulb is a 35w a 35w HID will not burn up the wiring.
post #6 of 33 Old 12-04-2008, 10:32 AM
Make a how-to on it and you will have my personal admiration.
post #7 of 33 Old 12-04-2008, 12:16 PM Thread Starter
I'm thinking i might try those PIAA bulbs first, as their cheaper than an HID kit and just plug and play.... we'll see... i'll take pics if i do it.
post #8 of 33 Old 12-04-2008, 01:48 PM
post #9 of 33 Old 12-04-2008, 04:55 PM
OzLinc's Avatar
This guys name is Rich and his kit is supposed to be about the best going. I would think the TRX450ER kit would work fine but contact him coz he'll know.
http://simpleracing.com/v1/catalog/p...9707a2037c671a
All reports indicate this kit is reliable and very high performing. It comes with a HD wire harness.
OzLinc is offline
post #10 of 33 Old 12-06-2008, 01:31 AM Thread Starter
FYI...
To get to the lightbulbs is very easy. Take off the red or gray plastic, the obvious 6 hex head (5mm i think) bolts take them out. Then a 10mm bolt is tucked in, inside the fender on each side and the headlight assembly will twist out very easily.
I took mine apart tonight just to see how easy it was... very.
