new piston, hard start. - Club700XX - Honda TRX700XX Forum
post #1 of 5 Old 12-27-2014, 11:14 PM Thread Starter
Quoted: 4 Post(s)
If i have the 11:1 cps piston in the 700 should i have a programmer?
jonLAY19 is offline
post #2 of 5 Old 12-28-2014, 08:23 PM
Quoted: 5 Post(s)
yes
Elmer is offline
post #3 of 5 Old 12-29-2014, 01:19 PM
Yes, would be the simple answer... Because your motor will now require more fuel. You should also check out a new battery with more CCA (Cold Cranking Amps) With higher compression, you need more Amps to crank at starting speed.
post #4 of 5 Old 12-31-2014, 11:30 PM Thread Starter
Quoted: 4 Post(s)
alright, thanks guys for the answers!
jonLAY19 is offline
post #5 of 5 Old 01-06-2015, 12:21 PM
kdp
If the automatic decompression is not working properly it can make it hard to start. The higher the compression the worse it gets. If it is turning over with great effort like the battery is low but it is not then I'll bet that is what it is. You can do a search on the forum, there are threads on this.
kdp is offline
